S-Class (W222) 2014-2020
Vibration at 48 MPH
Old Aug 20, 2020 | 02:01 PM
Lumbe's Avatar
S-550 4 matic
Thumbs up THANK YOU
I purchased the tire saver and is working better, I snot 100% solution, maybe 50% improvement.
I believe that the tires are the main problem, the side walls are to stiff and help to develop flat spot, mostly because the front of the car is very heavy.
Thank you all for the good recommendations.
Old Aug 21, 2020 | 02:33 AM
Naserals's Avatar
W222
Originally Posted by Lumbe
I have a S class 2016 4 matic with run flat tires, every morning the car vibrates for a few miles and the the vibration fade away. I went to the dealer, fix the rims balance tires, check all system and they didn't fix it.
They told me that maybe are the tires, the are the Bridesgston 18" 400.
Any comment?
Did you check the transmission mount?
Old Aug 21, 2020 | 10:14 AM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Be sure to check the muffler bearings.
Old Aug 25, 2020 | 03:16 PM
Lumbe's Avatar
S-550 4 matic
Thumbs up Problem solved
After 3 days of the tire saver, no more vibration at any speed.
Problem Solved, thank's for all the sugestions.
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
Well, am glad i was able to help
