S-Class (W222) 2014-2020
S Class W222 Sticky Air Vent Controls
Old Oct 11, 2020 | 07:40 PM
tomwi11is's Avatar
S Class W222
Hi all, I am hoping someone can help me out and also knows what I mean when I say my air vent controls on my S Class W222 have become sticky. When I press them to get the little dial to pop out, many of them in the car get stuck and either dont pop out at all or they only pop out a little bit. Does anyone have any experience of this, or any fix?
Thanks in advance.
Old Oct 15, 2020 | 12:39 PM
konigstiger's Avatar
'71 Pinto
Carefully pull trim to inspect, I believe replacement part # is 2228203097 need VIN to confirm.
Old Oct 15, 2020 | 01:07 PM
tomwi11is's Avatar
S Class W222
Thanks for the help. So I am clear, do you think removing some of the dash trim to the replace this entire part is what is needed? The worst dial I need to fix is actually located in the rear of the car to control the vents in the centre. Any idea how I access that dial?
Old Oct 15, 2020 | 01:29 PM
'71 Pinto
I would not recommend spaying any type of lubricant or cleaner into potentiometer (MB part description). Part # is same for rear. My suggestion is to remove trim and check part from behind to see if you can remedy malfunction if not, most likely you will need to replace part should be plug & play. Carefully remove rear cover with air vents using plastic wedge start at top.
Old Jan 12, 2023 | 11:11 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Does the rear have 2 peteniometers?
I have codes for this and am going to replace.
Old Jan 13, 2023 | 11:01 AM
'71 Pinto
Your VIN shows 1.
Old Jan 13, 2023 | 12:05 PM
vincheung's Avatar
S63, GLE580, BV250
Also curious about this, would CRC QD Electronic Cleaner be a safe option for this or something similar?
Old Jan 13, 2023 | 12:08 PM
vinflouen's Avatar
They cost anywhere from $30-$100 ebay/dealer.
shop around, big price differences between dealers.
Old Jan 15, 2023 | 10:27 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Do not put CRC on interior trim, it's way too agressive.
Remove, clean with compressed air and apply krytox.
