Trunk would not stay closed
231-750-00-85, but the SL will have a different part
Going to be a few weeks before I can install it.
If you go to a dealer they can get the part sooner and will probably install it quickly, but you pay for that service.
I sprayed some silicone lubrication in there for now.
It took about an hour. I used the beginning of this video as a guide.
notes:
the only tools were a T30 wrench and a screwdriver to remove the plastic fasteners.
you only need to remove the trunk lid liner. You do not need to remove the arm covers, and do not remove the two square-holed bumpers. You will have to reach in and unplug the lights and buttons.
to remove the key cylinder, just loosen the T30 screw and turn the cylinder a quarter turn.
However this time that did not resolve the issue. Temps were below freezing for about a week before it happened. This time I resolved it by taking a screwdriver and manually latching the trunk while it is open. then i hit the red button on the trunk lid. The latch opened and the trunk went on to work as it should with no further issue. But im dreading the next time this happens that i wont have a solution.
I expect better from the benchmark luxury sedan.
2020 S560 4 matic
ORDER #32047 - Placed 02/06/2025
Thank you for your purchase! We will start processing your order shortly and will notify you with any updates. You can monitor the status of your order here.
Part Number
Part Name
Price
Quantity
Total
231-750-13-00
Lock
$450.74
1
$450.74
Subtotal: $450.74
Estimated Shipping to 34759 via Standard Shipping: Free
Total: $450.74
Lubricant didn't help and the green button only worked a few time, so I ended up having the latch replaced.
https://mbworld.org/forums/s-class-w...peratures.html
https://mbworld.org/forums/s-class-w...ml#post9149975
im a DIY and do almost all of our maintenance, but free sounds better to me.
I hope that helps.
