S-Class (W222) 2014-2020
Jack and wrench kit for 2015 w222
Old Apr 24, 2021 | 10:38 AM
Djackson13's Avatar
2015 s550
I recently purchased the spare tire for my 2015 S class. Just wondering if anyone can provide info on purchasing the jack and wrench kit that will work with this car. All replies will be appreciated.
Old Apr 24, 2021 | 06:17 PM
roviw1's Avatar
2015 S500, 2016 GL63 AMG
I think you will find this kit will work on the w222,
vehicle tool kit set | genuine Mercedes-Benz | A1665806900 (kunzmann.de)
Car Tool Kit Bag for Mercedes-Benz (mercteil.com)
I recently ordered this for a friends S class AMG coupe from the Mercteil website
For my own w222 I actually have a small trolley jack, wheel wrench and set of shorter wheel bolts stored under the boot floor, I have a w221 spacesaver in the boot for emergency use .
Old Apr 25, 2021 | 09:07 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Amazon.com: ROGTZ Electric Car Floor Jack Set 3 Ton All-in-one Automatic 12v Scissor Lift Jack with Impact Wrench and Tire Inflator Pump for Tire Change Replacement: Home Improvement Amazon.com: ROGTZ Electric Car Floor Jack Set 3 Ton All-in-one Automatic 12v Scissor Lift Jack with Impact Wrench and Tire Inflator Pump for Tire Change Replacement: Home Improvement
Old Apr 25, 2021 | 09:10 AM
Nice Ride's Avatar
Dont forget to check the Lugs, you may need 2 sockets. One for Lock Key and One for MB Chrome Covered Lugs, so kit may not work. You can update your lugs to standard heads.
Old Apr 25, 2021 | 09:22 AM
Nice Ride's Avatar
Amazon.com: Electric Car Jack 5 Ton 12V Hydraulic Floor Jack with Impact Wrench & Inflator for Car/SUV/Sedan/MPV: Automotive Amazon.com: Electric Car Jack 5 Ton 12V Hydraulic Floor Jack with Impact Wrench & Inflator for Car/SUV/Sedan/MPV: Automotive
Old Apr 25, 2021 | 09:23 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Those flower covered lug bolts take a standard 17mm socket. In fact, the MB lugwrench has the standard 17mm head. They do not require a special shaped socket or lug wrench.
Old Apr 25, 2021 | 09:27 AM
roviw1's Avatar
Thanks for mentioning that, I do have the 17mm sockets and also the special star shaped socket as well, although the standard wrench will fit as well, when I bought the spare wheel I double checked the size of the bolts, the heads are standard 17mm but the length of them are much shorter as it is a steel wheel, I think from memory the spare wheel bolts are just 27mm long but don't quote me on that.
Old Apr 25, 2021 | 10:10 AM
Nice Ride's Avatar
They swell sometimes from corrosion under the Chrome plated cap. To remove a swollen one you will need to hammer on the lug wrench and have a heck of a time getting it out as well as not possible to reuse is most cases.
I ended up getting a new set ( which most 2021's have no chrome caps anymore ).
Old Apr 25, 2021 | 10:14 AM
roviw1's Avatar
I did not realise the Merc bolts had this issue, the Jaguar XJ have a similar problem , the models from 2004 to 2009, the chrome covers are awful, a lot of guys have found that Toyota lug nuts work well as they are the same size and shape.
