S-Class (W222) 2014-2020
Ceramic Pad Recommendation?
Old Jul 14, 2021 | 11:57 AM
Jim Ma's Avatar
S 550, S65 Coupe
Does anyone have an aftermarket low dust Ceramic pad that they are happy with? I used to use Akebono on previous cars and they were great but they don’t make a front pad for the S550. I purchased the Brembo Ceramic pads and they are just as bad as OEM pads for Brake dust buildup. Anyone have any recommendations on what may be out there that is really low dust?
Old Jul 14, 2021 | 07:21 PM
dweb4's Avatar
S550 4-matic
You can check buybrakes.com and also brakeperformance.com, I've used these both the get low dust pads that still have great stopping power. Definitely better then the heavy OEM dusters.
Old Jul 14, 2021 | 11:06 PM
vinnybenz's Avatar
2013 GLK350 2016 GLE400 2019 E450 Wagon 2018 S560 2021 E450 AT
Well folks, I just spent a Saturday morn in my driveway with my music on and changed the pads to POWER STOP Z17 Evolution Clean Ride Ceramic. I have used these pads on all my cars over the years with no complaints. Front and rear, all for under $80 bucks and no more dust to worry about
Old Jul 14, 2021 | 11:17 PM
Jim Ma's Avatar
S 550, S65 Coupe
Thanks for the websites. Has anyone tried the Hawk Ceramic Pads yet?
Old Jul 15, 2021 | 12:44 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
I have been running these for about 6 months. Extremely Happy. No noise, extremely low dust. Pads come with a complete set of hardware.
2014 Mercedes S Class Performance Brake Pads - CARiD.com
Old Jul 15, 2021 | 10:55 AM
compaddict's Avatar
2016 S63, 2013 SL63
I have used Power Stop Z16 Evolution Rear Ceramic Brake Pads on my last two S63 and they are great. A little bit harder pad but very little dust.
Old Jul 15, 2021 | 11:04 AM
Gazwould's Avatar
S204 C250 CDI Sport
EBC Redstuff full sets on 3 cars with satisfaction , been buying them since around 2007 .
But they're expensive and now there are many ceramic choices .
Pops not long put on Ferodo Eco Friction up front
( not quite bedded ) but I haven't washed the wheels yet to observe the dusting .
Old Jul 15, 2021 | 07:33 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Very happy with EBC Red, and yes, they are expensive
Old Jul 16, 2021 | 02:07 PM
emilner's Avatar
S560
Yes, 3 months ago I changed out the pads in my S560 to Hawk CPs. So far I am pretty happy- no noise, but a slightly softer pedal and about an 80% reduction in dust. Not quite as zero dust as I hoped but after a few hundred miles of city driving they aren't charcoal anymore. I also swapped the front on my SL to Hawk (but not the rears as they apparently don't make them). In the SL, which is driven much more spiritedly, there is a substantial reduction and it's quite noticeable that the fronts are cleaner than the rears when it used to be the fronts looked dirty and the rear not nearly as much.
Old Jul 16, 2021 | 02:48 PM
compaddict's Avatar
2016 S63, 2013 SL63
Softer pedal?
Weird, the last four MB I changed pads on (Akebono and Powerstop) had a much firmer feel.
I was thinking the pads were much harder. As long as the bulk of red dust in gone I would be happy though!
Old Jul 27, 2021 | 09:06 AM
Finn Donati's Avatar
Mercedes-AMG S65
My S350 diesel, with amg sportpaket, has 370mm front roters.
I have been unable to find any supplier of ceramic pads.
Anyone know if some of the US version S-class, share the same brakes?
Old Aug 1, 2021 | 06:32 PM
Jim Ma's Avatar
S 550, S65 Coupe
I ended up going with POWER STOP Z17 both front and rear with new OEM front rotors and I had the rear rotors turned as the had plenty of life left in them. The pad kits had all new hardware so I swapped that out as well. I also bled the brakes so I could change out all the old brake fluid. After 500 miles very pleased with the lack of brake dust and performance of the new pads. Haven't even had to clean the wheels as the brake dust buildup is negligible. Much, much better than the Brembo Ceramic pads I had prior. The initial bite of the pads is also good. I have used Akebono many times in the past and the bite was a drawback of their pads but these Power stop Z17 seem great in initial bite. Only complaint I would have is that they didn't come with new wear sensors. Other than that they have been great and I would definitely recommend them.
Old Aug 1, 2021 | 06:49 PM
vinnybenz's Avatar
Jim, I agree, the Power Stops are great all around. Used them on many cars.The sensors are sold separately because most times, the existing ones are still usable.
Old Nov 24, 2021 | 03:50 PM
Fred2's Avatar
Sprinter, agate grey sports car, e350 Wagon, S
Swapping out the front pads was a no brainer.
however
It looks like there may be a trick to the rear calipers.
How do you push the piston back in the caliper?
Old Nov 24, 2021 | 04:01 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
however
You have to go into the Service Menu and select "Brake Pad replacement".
Old Nov 24, 2021 | 04:02 PM
compaddict's Avatar
2016 S63, 2013 SL63
Yes there is! Do a search for that in google, it is a service mode through menu button pushes.
Old Nov 24, 2021 | 04:59 PM
vinnybenz's Avatar
TO REPLACE REAR PADS
1 – open hood and suck out some brake fluid and leave cap loose
2- take tire off and loosen the caliper bolts- DO NOT REMOVE CALIPER YET now gently remove the sensor and then socket with an E12 Star socket STILL DO NOT REMOVE CALIPER HOUSING!
3 – get in car and close door, turn car on to release the EPBrake handle. Shut car off then MAKE SURE YOUR FOOT IS OFF THE BRAKE PEDAL!! press ignition to 1 position only, pull EPB handle again to be sure brake is off
While in ignition 1 position, make sure odometer/mileage is on screen, then hold down the Home/back arrow down for 5 seconds and then tap once the mouse/OK button to bring up the ‘Workshop Tools’ menu
4 – go to ‘brake pad replacement’ , OK, then you see ‘Move to fitting Position’, OK, you’ll hear the caliper noise momentarily with ‘Moving to Fitting Position’ on the screen, just wait for it to finish!
5 – you now will see ‘Fitting Position Reached’ . DO NOT PRESS OK ! Leave on the screen. Now go to remove the caliper housing. GENTLY take out pad with sensor out, then other pad and metal pad slider plates. GENTLY hang the caliper with hook.
6 – GENTLY press in the piston, then place the new slider plates, then plain pad 1st, then sensor pad in with sensor installed
7 – re-assemble caliper housing, the sensor plug and socket, wipe down the area
8 – QUICKLY GO BACK TO THE CAR AND CLOSE DOOR AND TAP THE ‘OK’ BUTTON TO exit the Fitting Position. You will now hear the piston sound again and WAIT for the ‘Exiting Fitting Position’ to finish.
You now will see ‘Fitting Position has been exited’ and you hit OK
9 – you can now exit the Brake Pad replacement tool and go back to TRIP on the screen
10 – NOW OPEN HOOD and close the fluid container. Turn car on and gently press brake pedal a few times and then check level in the reservoir. If all is well, then you’re done.
TO REPLACE ROTORS
You must do all of the above pad replac procedure
After rotor is removed, brush and clean hub, regrease the seat, place rotor on and re-screw with 10 Newton Meters
Old Nov 24, 2021 | 05:08 PM
Fred2's Avatar
Thanks all for the hints.
The car in question is a newer one, so the buttons on the steering wheel are a little different.
I'll have to see if I can make them work.
Old Sep 11, 2023 | 05:36 AM
monergist's Avatar
2016 S-550
thanks, was wondering was the price tag worth it for the brembo, and was also wondering if the z17 was okay, since the z23 are hard to find, plus i'm not a sports driver, just need regular commute stopping power.
can't wait to not have to clean my wheels everyday anymore
Old Sep 11, 2023 | 06:43 PM
Gazwould's Avatar
S204 C250 CDI Sport
Is Ferodo available to you ?
Old Sep 11, 2023 | 09:47 PM
monergist's Avatar
2016 S-550
I saw Ferodo on FCP Euro, but the ones they sell are semi metallic.
Old Sep 12, 2023 | 02:03 PM
2012 merc amg's Avatar
2018 S560
I did the power stop z23's on my car with the power stop rotors front and rear, all in all about 1000 dollars in parts. Very happy with the choice. Pedal is a little harder than stock but not too much. Car stops great. Wondering how long I'll get outta these over stock. Stock was about 40K miles hoping at least double that with these. No brake dust at all which is really nice.
Old Sep 13, 2023 | 05:14 AM
George A.'s Avatar
Mercedes S550
Agree. I changed to Powerstop Evolution Sport Z23 Carbon Fiber Ceramic pads. Have been very happy with the lack of black dust, and the performance is fine. I am a conservative driver, and do not do many fast runs or quick stops, etc.
