S-Class (W222) 2014-2020
Tire pressure warning came on
Old Oct 3, 2022 | 10:22 AM
zitsky's Avatar
2020 S560 4Matic
I've only had my vehicle for two months or so. I haven't been in my vehicle for a week and a half. Covid, working from home, etc. And it's gotten a bit colder. Tires are Michelin Primacy MXM4M 19"'
Today warning light came on. 3 tires at 37 psi, one at 38 psi. It didn't like the 37 but in warn weather it was not unusual to start at 37 and go up to 40. Do you follow the sticker on the door or the sticker by the gas cap?
Old Oct 3, 2022 | 10:29 AM
superswiss's Avatar
2019 C63CS
The warning is based on the pressures that were last set as reference. Given you only had the car for two months, unless you adjusted the pressures and then set them as the reference yourself, there's no telling what the reference pressures currently are. Adjust them according to the the gas cap and then reset TPMS.
Old Oct 3, 2022 | 11:55 AM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
You should follow the gas cap, not the door. I actually run mine at 31, not the 35 on the gas cap.
Old Oct 3, 2022 | 12:29 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Yes, set the cold pressure on all four tires to your desired level, then go into the service menu and reset the reference pressure. The system will then compare the TPMS results to the reset reference numbers and the warnings will go away ... for a whlie.
Old Oct 3, 2022 | 03:39 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
Speaking of which::
anyone know of a way to get the tire pressure scene to "come up" so it is easy to see what the car thinks the pressures are ?
Old Oct 3, 2022 | 04:01 PM
konigstiger's Avatar
'71 Pinto
Try this...
Old Oct 3, 2022 | 04:17 PM
superswiss's Avatar
2019 C63CS
Originally Posted by Mitch Alsup
Speaking of which::
As shown above, for the regular MB models as far as I know it's only found under the service menu. AMGs should have a separate display as shown below, that shows all the powertrain and tire temps along with the tire pressures. It's pretty much one of the standard displays I have up at all times and so far has resulted in detecting two punctures shortly after pulling out of my garage and noticing that the tire pressure in one tire is lower than it should be.
Old Oct 4, 2022 | 09:38 AM
zitsky's Avatar
2020 S560 4Matic
I should have written down the "original" tire pressure when I picked up my vehicle. I want to say it was 40/41 warm.
This morning, cold tire pressure was 35 front & rear. Then went up to 37 front and 38 rear warm.
I'm trying to decide if I want to set it back to higher? I think I do. Gas cap label says 38 max front and 39 max rear, COLD. Maybe set it to 41 front and 42 rear? Does it really matter if I am 1-2 psi over the MAXIMUM? By the time I get to my tire shop my tires have warmed up a bit.
Sorry if this is a basic question. I haven't had run flats before so I'm trying to figure out what is best for them.
Old Oct 4, 2022 | 09:59 AM
SW20S's Avatar
2024 S580
Don’t set it back higher, it rides MUCH Better at lower pressures.
Mercedes recommends a pressure, worst case just use that and it’s 35.
Old Oct 4, 2022 | 10:09 AM
zitsky's Avatar
2020 S560 4Matic
That’s 35 cold yes, so warm might be 39? So 35 cold would be your target yes? Can you let it go below that? I did get the feeling that 40 plus was a bit high.
Old Oct 4, 2022 | 02:07 PM
SW20S's Avatar
2024 S580
Don't worry about warm, the pressures are set cold. Whatever pressure they are warm is whatever they are.
I run mine at 31 cold.
Old Oct 4, 2022 | 02:39 PM
zitsky's Avatar
2020 S560 4Matic
What tires and what size, please?
Old Oct 4, 2022 | 05:35 PM
SW20S's Avatar
2024 S580
Same as yours AMG 19s, I had Michelin Primacy non runflat and now have Pirelli PZero non runflat, runflat vs non runflat makes no difference for pressures.
Old Oct 4, 2022 | 07:19 PM
zitsky's Avatar
2020 S560 4Matic
Ok thanks for all the advice!
Old Oct 4, 2022 | 08:41 PM
SW20S's Avatar
2024 S580
Anytime!
Old Oct 5, 2022 | 10:56 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Cool
Suggestion, set cold in the early AM before Sun hits the car. If you park outside, depending on sun location it may heat up 2 tires on the sunny side. This will affect tire pressure by 2 to 3 lbs. If you're in a garage, your good to go.
Old Oct 5, 2022 | 01:05 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
If you have a Costco nearby you can use their system which enables you to pick exactly the pressure you want and then it stops automatically when you hit it. I have the Primacy MXM 19" and I have done this twice in 3 years to get all the tires back to exactly where they need to be.
Old Oct 5, 2022 | 05:40 PM
SW20S's Avatar
2024 S580
Just get yourself this little compressor for your garage that does the same thing, works great:
Amazon Amazon
Old Oct 5, 2022 | 06:00 PM
'71 Pinto
My wife and I each have one: https://www.lowes.com/pd/Kobalt-DC-1...ric/1000092575 can’t believe how the price has increased since we got ours.
Old Oct 5, 2022 | 06:41 PM
SW20S's Avatar
2024 S580
Yeah I paid under $50 for mine I'm pretty sure...
Old Oct 6, 2022 | 03:38 AM
BenzV12's Avatar
W212 FL
I had bought of Michelin's compressor, and it works like a charm.
superswiss's picture is great too, I think I may find a new desktop image
Old Oct 6, 2022 | 08:43 AM
will_atl's Avatar
2020 S450 4Matic, 2022 GLS450 4Matic, 2015 C300
I have a Ryobi 18+ compressor in the garage that I use most often, and the kids use it to inflate soccer ***** etc..
I also bought a Slime - Flat Tire Repair Kit - Digital that I threw in the trunk, I figure that if I get a flat on the run flats while on a road trip, this may get me going again without having to rush to a tire shop, I also bought a tire plug set. But truth be told, I don't remember the last time I got a flat (famous last words!)
Old Oct 7, 2022 | 10:28 PM
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, A238 E400 Cabriolet 4-Matic
We run all our MB's at 40 PSI. Easy to remember, helps with fuel economy, extends tread life & you're good up to 165 MPH or so They may run a tad bit rougher if your roads are really bad (?) but most of our cars have air suspension to help smooth things out.
Old Oct 8, 2022 | 01:00 AM
SW20S's Avatar
2024 S580
IMO, the car rides like a completely different car at a pressure like that...I bought the car for it to have an excellent ride, and if that means I have to buy tires more often so be it. If I cared about fuel economy and tire cost I wouldnt be driving this lol
Old Oct 8, 2022 | 09:20 AM
zitsky's Avatar
2020 S560 4Matic
You people buying compressors. I refuse to believe a Mercedes-Benz owner would do it themselves. Don’t you people have servants for these things?
