S560 Winter Tire recommendations?
Currently running 20" wheels/tire setup. My plan is to swap current summer tires for winter tires. Winter tire recommendations are appreciated!
Also, to confirm my understanding, any tire is acceptable as long as I maintain the current size and XL weight rating?
Thanks,
Thanks,
Thanks,
Not true. I have an 2019 S63 AMG and the tires were purchased for me by the dealership where I bought the car and I checked with Mercedes USA before I bought them. I’ve used them now for three winters swapped out in summers with the original tires. I’ve had no issues. Thanks for your reply notwithstanding.
Thanks for all your feedback. When I bought the vehicle I specifically checked with MBUSA which said unequivocally “yes” the tires were fine to use as winter tires, which is why I went ahead and bought them. Given the feedback here from you all I will check again tomorrow both with dealer and MBUSA itself. I’ll let you all know what the response is. Thanks again for the helpful feedback. So far have not had any issues whatsoever but given what I paid for the vehicle surely not taking any chances. This is a subject for a different thread but one constant issue I have faced is steering column has regularly stuck in terms of up and down driver adjustment (telescoping works fine). I had to have the entire steering column replaced but notwithstanding the up and down adjustment still sticks until I several times manually move the knob up and down after the car has run a bit. Has been a very annoying defect.
