S-Class (W222) 2014-2020
Rear Defroster
Old Nov 16, 2022 | 08:27 PM
Denis Osullivan's Avatar
2018 s560v4
Rear Defroster
Can someone explain how the rear window gets defrosted? After activating switch on the console it takes forever to have a clear window. I don’t see any wires on the glass other than the radio antenna on the upper 3 inches.
Perhaps it was an option that isn’t on my car?
Old Nov 17, 2022 | 02:19 PM
Sactownmb's Avatar
MY 18 S450V RWD Diamond White
Denis, your rear window does clear after a few minutes? So it is working just slowly. I believe that rear window defrost is standard equipment on mb products. I know my wife’s 2006 Honda Accord had rear window defrost.
Old Nov 23, 2022 | 07:44 AM
AbbyKay's Avatar
2020 S560 4Matic
The heating comes from very fine wire mesh in the window. Not like conventional rear window defrost wiring. You’ll notice the glass isn’t perfectly clear if you look at it closely. You have the rear window defroster, it just looks different than what you are used to.
Old Nov 23, 2022 | 08:24 AM
2018 s560v4
I now notice these fine lines in the glass. But I’m thinking there is an electrical issue as it dissipates from the top down as if hot air is blowing on it but I never see it clear up because of these lines.
Old Nov 27, 2022 | 12:57 AM
JohnLane's Avatar
222 S-65
Dennis.... Move!
Never needed to use any defroster here in Phoenix!
Also haven’t had to shovel any of the sunshine.
Old Dec 8, 2022 | 05:42 PM
konigstiger's Avatar
'71 Pinto
See attachments
File Type: pdf
File Type: pdf
Old Dec 8, 2022 | 05:51 PM
DABRONX's Avatar
E55
Funny when moved from CA to East Coast and actually turned on defroster I swore car didnt have one either as it was so slow it was ridiculous.
