S-Class (W222) 2014-2020
Tuned at 93 Octane Question for Road Trippers
Old Dec 7, 2022 | 12:48 PM
vincheung's Avatar
S63, GLE580, BV250
Took a trip up from NYC to Montreal & Quebec City recently and realized that outside of Montreal going north only 91 is available (my tank lasted with 93 in it for the round trip but it was getting low). In NYC and surrounding states 93 octane is readily available, i'm ecu tuned for 93 also. Just wondering what other 93 tuned guys do for longer distance drives where 91 octane is the max available at the pumps. Octane Booster? Run with 91 with more conservative driving? Knock sensors still compensate when 93 tuned?
I poked around online/reddit and didnt really walk away with any good information.
Old Dec 7, 2022 | 04:14 PM
badq45t's Avatar
2016 S550e, 2005 Nissan Xterra 4x4, 1984 300ZX
I can only buy 91 in CA and I have added octane booster to see if the power and gas mileage was any different. I haven't done any tuning (not sure the 550e has available tune) but mileage and power seemed the same with and without the booster.
Old Dec 7, 2022 | 07:35 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
Who did your ECU tune? I think asking the tuner would be the most beneficial.
Old Dec 7, 2022 | 09:37 PM
Donnymac's Avatar
63 Falcon vert
The compression ratio of your motor does not need 93. It will live just fine on 91.
Old Dec 8, 2022 | 06:44 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
A lot of this octane stuff is dependent on how you use the car.
a) if you are always flooring the throttle--you best stick with as high an octane as you can get.
b) if you ease away from stops and ease up to cruising velocity--you need nothing more than mid-range gas.
c) live in mountains and use cruise control up and down hills--probably better to stick to higher octane
d) live near sea level and use throttle to keep distance from others--best to stick with higher octanes.
I use mid-grade gasoline with nary an issue in 7 years.
Old Dec 14, 2022 | 03:52 PM
nybenzo's Avatar
w222 550
Whats mid grade? 89? We don't have 91 here in NYC. Its 93 or 89.
Old Dec 14, 2022 | 11:23 PM
vincheung's Avatar
S63, GLE580, BV250
Thanks for all of the comments, I know that 91 for stock mapping wont be an issue. Looking for input from what 93 tuned guys do when they have road trips into areas where pump premium is 91 only.
Old Dec 15, 2022 | 05:07 PM
MBNUT1's Avatar
2010 E350 4Matic
As Mr Alsup suggested just keep your foot out of it when you are running the lower octane fuel.
Old Dec 16, 2022 | 06:34 AM
will_atl's Avatar
2020 S450 4Matic, 2022 GLS450 4Matic, 2015 C300
Originally Posted by nybenzo
Whats mid grade? 89? We don't have 91 here in NYC. It’s 93 or 89.
Mid grade is 89 here in GA, we have 87, 89 and premium, which don’t remember whether it’s 91 or 93! I’ve been using it for years, and it shows how little attention I show when I’m at the pump 🤦🏻‍♂️
I just filled up, we have 93 in GA!
Old Dec 16, 2022 | 10:34 AM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
He's got a tune is the issue...stock 91 will be fine.
Old Dec 16, 2022 | 01:50 PM
Bigg Willi's Avatar
Veteran: Air Force
| 2015 S63 / 2013 5.7 Tundra |
I have a handheld that lets me switch my tune from stock to moded (91) to race (93) since CA smog now can see a moded tune.
Old Dec 17, 2022 | 08:04 PM
Donnymac's Avatar
63 Falcon vert
In what measurable ways can you tell the difference?
Old Dec 18, 2022 | 12:53 AM
cfmistry's Avatar
You can buy octane boosters from any auto parts store. That should work. But again, I would recommend asking your tuner.
