S-Class (W222) 2014-2020
Am I missing a drain tube?
Old Dec 23, 2022 | 10:52 AM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Hi Team 222.
This is under the right front side of the car, just behind the right front tire.
Recently I changed the fender liner and replaced one large drain tube, (the one everyone says makes a dragging sound after a large puddle, when it falls out, I super glued it in)
I did notice what looked like another connection for a drain tube behind the large one I reinstalled.
you can see the outlet for the large drain tube that I reattached, but what is supposed to come out of this hole?
See this hole? Am I missing a drain tube?
Am I missing a drain tube on the right front?
Notice the large drain tube lip in the right side of the pic
Old Dec 23, 2022 | 04:13 PM
Merserybenze's Avatar
2022 AMG GT 53, 2020 Sl450. Did drive 2018 S450
Mine fell off. How did you get to it to glue it?
Old Dec 23, 2022 | 05:45 PM
vinflouen's Avatar
Took fender liner off (wheel well)
I Put glue on the inside and put it back on.
When you take the wheel liner off you will see to the upper left where it slots in.
Put glue on the inside of the drain pipe as it sits over the housing.
what I am trying to be sure of is, are there only 2 drains that come out of the front? Or does that have a missing one for that hole?
Old Dec 23, 2022 | 05:59 PM
konigstiger's Avatar
'71 Pinto
Old Dec 23, 2022 | 08:01 PM
vinflouen's Avatar
thank you for that Intel.
That solves it, there are only 2 drains out.
Old Dec 24, 2022 | 03:17 AM
ebceksl's Avatar
Mercedes S 500 4MATIC W222 (2015)
That's the hole for the exhaust pipe for the petrol/diesel heater, in case you had that option.
Old Dec 24, 2022 | 07:27 AM
Bart-N3GQ's Avatar
Veteran: Army
2016 S550, 1995 E320, 1996 Jeep Grand Cherokee
Drain Tube Fell Out
Thank you for posting this. My drain tube fell out a few days ago as I was exiting an interstate highway, scraping against the road. Glad it wasn't something more serious.
Old Dec 24, 2022 | 11:45 AM
vinflouen's Avatar
Thank you, now I know.
as far as the tube falling out.
It sits in it's slot pretty shabbily and you need to use some good glue to make it stick.
note the way it installs so you see where to put the glue.
Good luck merry christmas
Old Aug 15, 2024 | 02:22 PM
capt timmy's Avatar
2019 S560
S560 Drain Part #280
Thanks for the info Vin, my part #280 just fell out. It was dragging, I stopped and saved it. Do you think it is necessary? I'm thinking of leaving it out. Any real need for this thing? Seems like an afterthought the way it is installed. Rgds, Tim
Old Dec 19, 2025 | 01:50 PM
lancelot092466's Avatar
2003 C320
Hey Tim, did you ever get a response to your question? My part #280 fell out today after driving thru a puddle. It was dragging on the ground so I pulled it out. It is not salvageable so it will need to be replaced. I will make an appointment with MB dealership but I would prefer to wait until the A service is due (two birds one trip). So how long can drive around without the drain pipe?
Old Dec 19, 2025 | 08:08 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
I drove around for about a week the first time mine fell out. Replaced it, and it fell out again during the next heavy rain. I drove around for a couple of months until a service was due, then I had the dealer fix it under warranty. You won’t have a problem driving without it - in fact I would bet there are a significant number of W222s driving around unaware that theirs is missing.
Old Dec 29, 2025 | 09:27 AM
capt timmy's Avatar
2019 S560
I still have mine in the trunk with no intention to reinstall it. Seems totally superfluous and horribly designed in regards to just staying in place.
