S-Class (W222) 2014-2020
Squeaky Wheel Sound when Engine is Cold 2018 S560 4Matic
Old Jan 10, 2023 | 04:43 PM
Dellserv's Avatar
W222 S560 4M
Hi all,
I have a 2018 S560 4M, warranty just ended. I noticed that when I start the car in the morning, I hear a squeaky wheel turning inside of the engine bay.
The car runs without issues, even when, standing behind it, it rumbles nicely from the exhaust tips.
maybe I’m noticing it more now? I am annoyed by it a bit. here is a short video I took:
https://youtu.be/6jTNPiJA_EM
what do you think?
dellserv
Old Jan 10, 2023 | 07:37 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Never easy to tell from video but most likely a pulley, remove V belt and start engine (briefly) to check.
Old Jan 10, 2023 | 10:14 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Agreed, usually the pulley goes bad. Mine went out at 38k. I still get a small chrip on cold mornings.
Old Jan 11, 2023 | 08:45 AM
Dellserv's Avatar
W222 S560 4M
is this something that would be covered under warranty or prepaid maintenance?
Old Jan 11, 2023 | 10:28 AM
konigstiger's Avatar
'71 Pinto
Factory warranty for sure. If warranty expired 30-60 days ago request MB (with dealer support) approve goodwill repair.
Old Jan 11, 2023 | 10:37 PM
vinflouen's Avatar
Also keep in mind the Benz's sound different in different types of weather....
Old Jan 12, 2023 | 04:19 PM
Dellserv's Avatar
W222 S560 4M
Thanks - it was the Certified Preowned Warranty that expired, not the original Factory Warranty (that one expired a year ago). Ok I googled that there is a bunch of pulleys that need to be replaced if it squeaks...
Old Jan 12, 2023 | 04:21 PM
'71 Pinto
Still, doesn't hurt to ask for goodwill if within 30-60 days of expiration.
Old Jan 15, 2023 | 01:29 AM
Nice Ride's Avatar
2014 S550 AMG, 2017 XT5
Hi all,
what do you think?
dellserv
Squirt some water or Belt Dressing on the belt and see if it stops. It will help point the finger...
Old Feb 14, 2024 | 10:21 AM
_Christinelynn_'s Avatar
S560
I have this issue too...
I have this issue and the dealership did fix the pulley under my certified preowned warranty... But, the sound is back about a month later and so its back with them today. I was already prepped with "we may need to replace the belt itself this time" which is not a warranty covered item (wear and tear). They specifically told me the belt looked perfectly fine last time, so I don't feel confident that they won't just charge me to replace the belt to see if that works. I am a bit distrusting of the dealership at this point due to past experiences. The sound goes away once the vehicle is warmed up or if it's a warmer day in general.
Old Feb 15, 2024 | 12:32 AM
vinflouen's Avatar
I replaced all my pulleys and belts, still does the same thing, goes away when warmed up.
All Mercedes make different sounds in different weather.
Old Feb 15, 2024 | 12:30 PM
Lou B's Avatar
Veteran: Army
Mercedes S560
As it happens, our famiiy business, later sold, was built around v-best drives. From all that I was taught, learned as a field salesman, pulley (actually, the correct term is "sheave;" pulleys in the world of mechanical power transmission are flat and run with flat belts, no v-belts.) sheaves rarely wear out. The problem usually arises from the v-belt, and the most common cause in a single belt drive is improper belt tension. Belt dressing is a waste of time and money in attempting to resolve belt slippage, not to mention creating a mess.
OF course, this is maintenance problem.
In my car ownership of over some 70 years and some 30 + cars of a variety of import and domestic makes, including 5? 6? Mercedes, I've have no recollection of hearing an automotive v-belt aqueak.
Old Feb 15, 2024 | 12:46 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Welcome back!!! We've missed you!!
Old Feb 15, 2024 | 07:53 PM
MBNUT1's Avatar
2010 E350 4Matic
His post was a year ago.
Old Feb 15, 2024 | 07:54 PM
MBNUT1's Avatar
2010 E350 4Matic
Are you saying that you have replaced your belts on a scheduled basis and thus precluded belt squeaking?
Old Feb 17, 2024 | 03:14 PM
Lou B's Avatar
Veteran: Army
Mercedes S560
I neither said or implied that. If belts were changed or tightened, it was done at a dealer service. No way I could possibly remember if tht happened.
Reread for comprehension.
Old Feb 18, 2024 | 02:34 PM
Nice Ride's Avatar
In my opinion, don't use up your good will repair for something that is not expensive. They only will assist once...
