Need wheels
19" factory.
If I was you, I’d go aftermarket. But beware the Sport Pack calipers require a lot of clearance behind the spokes.
Is there a spare tire solution that fits the front & rear ? Certainly the run flats contribute to this problem.
The fewer spokes the easier it is to clean.
Polished anodized aluminum does not show the brake dust that painted aluminum wheels do.
The wheels are about 7 pounds lighter, each, and you can feel it at the steering wheel.
{That model, ordered Jan last year, no longer appears in their web site.}
I have factory 19 wheels on mine, no issues.
Get rid of the runflats and you won’t destroy your rim.
Factory 19’s. Special order from Germany
hop on facebook market place and search 5x112. tons of options
im in maine our roads arnt terrible but they arnt the greatest either
If you tell me to remove run flats, and don't have a spare tire solution, I'm not listening.
I carry a plug kit, pump and tirefit kit. I’ve never had to use the tirefit / tire fix in a can and it would likely be my last resort (stranded in the middle of nowhere with no flatbed for days). Confident enough with just that to drive cross country NYC to LA/SD and up through north east Canada with just that.
I’ve patched a few tires on other cars in the past and am confident that a plug kit and pump will get you where you need to go for any patch/tire repair. I’ve had plugs left in for a few weeks before getting a proper patch with no issue.
Totaling my commuting, leisure, and work driving mileage I do about 50k annually on terrible roads with all sorts of random debris encountered. I’ve probably had to plug and patch maybe one or two a year.
Here's my thoughts, the run flat saved my life. Never lost control, Tire never flatted out. So the steering wheel wasn't yanked out of my hands as if the tire immediately went flat to the ground.
Surprisingly the rim wasn't damaged, because I never drove on a flattened out tire.
So run flats have their place, but the wheels need a better material to absorb the abuse.
