S-Class (W222) 2014-2020
Key Not Detected
Old Jan 31, 2023 | 12:01 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Key Not Detected
For some time, I've been seeing this message intermittently on the dash. Happens with either key, with or without new key batteries. Very sporadic, may go weeks without it, then it suddenly pops up after stopping for gas or something. Seemed to happen less often after I replaced by the main/starting battery and aux battery last fall, but hasn't gone away completely.
Of course I can take out the start pushbutton and just use the physical key, but wondering why this keeps coming up? Has anyone else experienced this?
Old Jan 31, 2023 | 12:24 PM
emilner's Avatar
S560
Aside from when batteries need to be replaced the only time I've had that happen is when my phone is in the same pocket as my key. The phone seems to mess with the signal.
Old Jan 31, 2023 | 01:14 PM
Thanks, I've been wondering about phone interference.
Old Jan 31, 2023 | 03:25 PM
TNS550's Avatar
2015 MB S550 & 2020 MB GLS 450
This happens to me very sporadically as well. Generally first thing in the morning, or if I'm leaving work. But as you say, occurs weeks apart.
Happened before and after I replaced Auxiliary battery, as well as key fob battery. Phone and key are always in different pockets, so I don't believe that is what is happening in my case.
Old Jan 31, 2023 | 04:43 PM
Mitch Alsup's Avatar
Top Answer: 1
S600
I get this message only when the old battery has died or when I was using 2032 battery instead of the 2025 battery.
Old Feb 1, 2023 | 01:23 AM
BenzV12's Avatar
W212 FL
It's happened to me in other cars (my W212 has not shown any key related messages ) . I just put the key near the keyless go detector around the steering wheel column and hold a few seconds and it goes away .
Old Feb 2, 2023 | 11:20 AM
kafklatsch's Avatar
All Cars Lost To Hurricane Isaac (W124 E420 revived - added 88 Allante 14 S550, 17 S63
I hope this doesnt happen while im being pursued by the walking dead (aka "the Ex").... because ive never figured when or why it happens.... but its about once every 4-6 months over the last 2 years
.....could become a beloved past forum member due to this issue
Old Feb 2, 2023 | 12:52 PM
Wondering, does this happen to facelift (18 and newer) cars too? If so, how do you get the car started, IIRC the facelift cars no longer have a place to insert a key?
Old Feb 2, 2023 | 01:41 PM
Quenthel's Avatar
S560 Long 4Matic (DE) MY 2018
It happened on mine, apparently the fob developed a problem making it go through the battery like crazy (one battery every two weeks). If that happens and it's not detected, you are supposed to put the key fob in a special area in the center console, which will supposedly allow the car to start.
Only in my case it didn't, I kept trying to get the car to detect the fob for 15' without success, until it suddenly worked. Since then I kept a couple batteries in the trunk until I went to the dealership for the annual service, told them about it, they replaced the fob and didn't happen again since then.
