S-Class (W222) 2014-2020
Pls help! Rear seat belt plastic guide ring collar broke in two and stuck in hole
Old Feb 16, 2023 | 03:22 PM
Chomolangma's Avatar
W222
Hi all,
I tried to replace a broken rear seat belt guide ring collar, but I turned it the wrong way and it snapped into two. The lower half of this plastic collar is currently stucked in the hole (as shown in pic below) and I have absolutely no idea how to get it out.
Any suggestions pls?
Old Feb 16, 2023 | 04:47 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Glue, super glue, carefully.
Old Feb 16, 2023 | 08:13 PM
W222
Thanks for your input. Just wondering have u encountered similar situation before and managed to solve it with super glue?
Old Feb 16, 2023 | 08:19 PM
VII's Avatar
VII
Yes, you have the piece that matches so the easiest thing is to glue it back in, you can also glue a random rod to it.
Gel presentation superglue.
Old Feb 17, 2023 | 07:19 AM
W222
Nice, thanks alot for the tip. Shall give it a go, fingers crossed
Old Feb 17, 2023 | 11:34 AM
DaveW68's Avatar
Veteran: Army
2015 S550
JB Weld is much stronger than Super Glue. You may want to put a ring of JB Weld on the broken piece, plus a few dots of Super Glue (not on top of the JBW) since that sets up quickly. After 24 hours it should be stronger than before it was broken.
Old Feb 17, 2023 | 11:36 AM
VII's Avatar
VII
He is not looking to repair, the piece is already broken somewhere else, he just needs to get it out without dissambling the seat (which is not too bad but will take a couple of hours).
Old Feb 17, 2023 | 03:25 PM
toodeep's Avatar
2015 S550
I need to replace the same piece on my rear seat. The old piece seems to be mounted pretty tight. Is there a technique to removing it?
Old Feb 17, 2023 | 03:37 PM
VII's Avatar
VII
Press down and then turn
Old Feb 17, 2023 | 06:11 PM
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
Happened to me but be careful not to glue your fingers crossed! LOL. Mine was covered under warranty and the MB dealership replaced it for me.
Old Feb 20, 2023 | 12:51 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Even if this is true, the JB Weld/Super Glue trick will work after the JB Weld has been set up for 24 hours. He can then push and twist the piece out of there.
Old Feb 20, 2023 | 11:48 PM
toodeep's Avatar
2015 S550
That worked perfect. It came out with no problem. I got the new unit in and I'm good to go. Thanks!
