S-Class (W222) 2014-2020
4-year old S560 with less than 4K miles. Risky?
Old May 2, 2023 | 09:45 PM
jumpman726's Avatar
2024 E350
What do you guys think?
A barely driven 4-year old S-class with under 4,000 miles. Out of warranty. If you were in the market for an S-Class would you consider buying it? Or would you stay away from it because of potential maintenance issues down the road with oil leaks, etc?
Old May 2, 2023 | 09:58 PM
Donnymac's Avatar
63 Falcon vert
Depends on the color and options. Shall I look at it for you? Free PPI! This week only!
Old May 2, 2023 | 10:33 PM
MercedesBenzers's Avatar
Golf 7R
I don't want to spoil anything, but with the M278 there's always risk at oil leaks. Maybe it was part of a rich man's collection, so that's why it wasn't driven all the time?
Anyway i'd ask if i could test drive it, and take it for a pre-purchase inspection. If everything turns out fine, just refresh all the oils and filters and you're good to go.
Old May 2, 2023 | 11:21 PM
vincheung's Avatar
S63, GLE580, BV250
Oil leaks are inevitable in pretty much all cars. Give the car a PPI and you shouldn’t have much to worry about.
Old May 3, 2023 | 12:20 AM
2012 merc amg's Avatar
2018 S560
Dealer service dept can check the vin number and give you a report on the cars service history and check to make sure it was not a lemon law car or something.
Old May 3, 2023 | 02:53 AM
BenzV12's Avatar
W212 FL
Low mileage is always tempting but could lurk some problems behind with it as well. Anyway, I would buy it how problematic can it be at this stage ? However, I would not buy if options and color combo don't meet my expectations
Old May 3, 2023 | 12:43 PM
jumpman726's Avatar
2024 E350
Carfax is clean except that it shows no record of having any service/maintenance done in the past 4 years. Maybe the previous owner did the service himself or took it to an independent shop, but I think it's more likely he never had it serviced since the car was barely driven.
The car looks beautiful though, interior and exterior. Just like new...obviously. It's currently priced a couple thousand above market value.
Old May 3, 2023 | 04:09 PM
MBNUT1's Avatar
2010 E350 4Matic
Thinking a 4 year old S Class wouldn't have a M278 in it.
Old May 3, 2023 | 04:48 PM
PeterUbers's Avatar
hell yeah ... low miles and basically new. Just needs brake fluid change, oil change and inspection, re bed brakes, and you're all set; these are modern cars not time bombs
Old May 3, 2023 | 04:49 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
I think the 2019 S560's come with the M176 motors. If the M176 motor is the same as the M177 then low mileage might not be a great thing. The M177 motor has popped up with some issues around rear main seal leaks due to overpressure in the crankcase. This overpressure is caused presumably by clogged catch can devices that can get clogged up if the car sits a lot and is not driven hard on occasion. The theory is the condensation and oil mix in the catch can passages and eventually clog them which then causes the overpressure. Only fix is to drop the motor out to fix the RMS.
Old May 3, 2023 | 04:51 PM
Golf 7R
Good morning! My bad! M176. Any engine is prone to oil leaks really. If it has 4 year old oil in it and hasn't been driven that often the seals might've dried out. So i would buy, and change oil very first thing. All the fluids.
Old May 3, 2023 | 08:28 PM
Highline-Autos.com's Avatar
SPONSOR
2001 E55AMG
Check out this extended warranty information from Fidelity, payout on the policy is the value of the vehicle and repairs are accepted at every Mercedes-Benz dealership and licensed independent in the country. You can reach out at tgibson@highline-autos.com or (855) 924-1333 if you have any questions or would like to see an example contract that explains coverage.
2019 Mercedes-Benz S560
4K Miles
Fidelity Platinum:
60 months / additional 60K miles:
$0 Deductible
-$3,978
$100 Deductible
-$3,578
$250 Deductible
-$3,505
TAX INCLUDED
Old May 4, 2023 | 05:01 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
I would enthusiastically buy that car
Old May 4, 2023 | 07:58 PM
cfmistry's Avatar
15 S550 4Matic, 86 560SL
I do not think that is risky at all. Might need a little bit of maintenance, but still better off than a 30k mile car.
Old May 7, 2023 | 03:35 PM
JohnLane's Avatar
222 S-65
OP this one isn’t due for its first oil change by miles. Bet the oil is still Amber in color.
No doubt it has lived all its life in the garage.
Have inspected and enjoy if color combination is good and if it has MBC.
Old May 7, 2023 | 09:48 PM
C280 Sport's Avatar
MB’s of all kinds.
I would buy it 100%
-Clean Car-fax
-PPI from dealer or shop
-Solid test drive
-Change all the fluids out for piece of mind. Enjoy it!
Old May 7, 2023 | 09:51 PM
WPHills74's Avatar
S450
Go for it provided it has not been in an accident!
