Thinking about changing the MBC hydraulic fluid
“Life of the car fluids.” I always ask... Just how long do you want that life to be?
MBC has a reservoir on the driver’s side of the engine compartment. I purchase that fluid from MB.
Your 222 car uses electric power steering so no tandem pump as in older models.
I suck the fluid out out of the reservoir, refill, then open each of the system bleeders around the car with the car on tip-toes, not running. Each corner of the car will drop with the corresponding bleeder. A clear hose going into the bleeder jug will make easy work of seeing when you have fresh fluid to each corner. Takes a dozen liters to do a nice job of it.
Don’t get it wrong with being in the way of the car as it comes down. Gravity is the enemy.
With XENTRY you can ask for a ‘Rodeo’ after fresh fluid for good measure.
