Installed a fixed charging point in the grill
Mercedes S 500 4MATIC W222 (2015)
I finally installed a fixed charging point in the grill of my car,.
Pic 1: CTEK cable set (3 meter).
Pic 2: Remove the 2 covers on passenger side.
Pic 3, 4, 5: Open the fuse box cover. Connect the pos cable with a M6 mutter to M1 in the fuse box, and the negative cable to the neg post.
Pic 6: Wire to the grill. Can be installed without remove the grill.
Pic 7: Install the charging point to the lower part of the front/grill.
The following 9 users liked this post by ebceksl:
BenzV12 (08-23-2024),
C Swenson (08-24-2024),
Gene Gorman (08-23-2024),
NbyNW (08-22-2024),
phil34 (08-22-2024),
and 4 others liked this post.
Great job, I didn't know such a product exists . Kudos to you for not messing the things up as well
Great solution for charging while keeping the car locked. Keep an eye on the connector for signs of corrosion. It seems to be at a height that could be susceptible to roadway splashback.
Looks good. Someone on here recently installed a magnetic charger port which is pretty cool.
https://mbworld.org/forums/audio-ele...ml#post9018710
