S-Class (W222) 2014-2020
Navigation Map Update
Old Nov 27, 2024 | 08:48 AM
Djackson13's Avatar
2015 s550
On my 2015 s 550, I recently had my command module replaced via warranty and am stuck with a 2015 version of the navigation mapping. :-( I am looking for suggestions on the best way to update the navigation mapping without taking to a dealer for this service. My research has revealed that there are some options such as purchasing a disc and installing an update myself etc. But, I am interested in knowing if any other w222 owners have done this before and what are t4he pros and cons..
I will appreciate any and all responses
Old Nov 27, 2024 | 09:39 AM
xabo's Avatar
'20 S63
Pardon my ignorance but shouldn't that be covered under the warranty repair/replacement?
Old Nov 27, 2024 | 01:44 PM
as.thompson's Avatar
Veteran: Air Force
S550C4, Porsche Cayenne
Contact Benz Ninja. He can provide the latest updates.
Old Nov 27, 2024 | 02:07 PM
Djackson13's Avatar
2015 s550
Hello,
Thanks for the response. I actually updated the nav map on my own about 4 years ago. And according to the Benz dealer, the replacment command module basically comes as the original module with factory settings which came with the car. I.e I having to reprogram my Radio stations and navigation destinations that were saved . and any updates that were installed after the factory settings will need to be re-installed :-) I am taking another subscriber's advice and hve reached out to Benz Ninja. I am hoping he can provide some good feedback for me on this.
Old Nov 27, 2024 | 02:08 PM
Djackson13's Avatar
2015 s550
@as.thompson.. Thanks for the great suggestion. I have reached out to Benz Ninja and am awaiting their response
Old Jul 24, 2025 | 07:08 PM
DOC_FEE's Avatar
2014 S550
Just came to say Hello Neighbor from beautiful Seattle. My vehicle shows the traffic color when I have the XM radio subscription active (2014 here).
Hope this helps!
Cheers!
Old Oct 27, 2025 | 09:28 AM
NbyNW's Avatar
Veteran: Navy
Various
Got an email from Mercedes a new map is available. I've done this before and it's clunky but it works, now I can't get it to select the thumb drive. It sees it, but the Select Storage Medium button isn't active. It's NTFS. ExFat gives an error and won't get this far.
I've removed the thumb drive, reformatted it, reloaded the page, downloaded the latest map loader... all the things I can think of. Suggestions?
Old Oct 27, 2025 | 10:28 AM
UltraSpeed's Avatar
GLS450 S550
Likely not enough space?
Old Oct 27, 2025 | 10:33 AM
NbyNW's Avatar
Veteran: Navy
Various
It needs 32 GB for all the maps and it has 465 GB free. It's empty and dedicated to map updates.
Old Oct 27, 2025 | 12:47 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
When I try to update, it fails at the next step:
Someday they'll hire someone who knows programming...
Old Oct 27, 2025 | 01:03 PM
NbyNW's Avatar
Veteran: Navy
Various
I get that error when using a drive formatted exFat. NTFS gets me to my screen ^.
Old Oct 27, 2025 | 06:33 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
USB might be too large try with something 128 or below
Old Oct 27, 2025 | 06:43 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
You might be running into the same problem I had. My car wouldn't work with a previously used USB stick. I had to buy a brand new USB thumb drive. Ironically; the second time around I was able to find the old one I used the first time, and that USB thumb drive worked. Just my $0.02 cents. I probably have 30+ used thumb drives around the house in varying sizes, and none of them worked.
Old Oct 28, 2025 | 03:32 AM
trigital's Avatar
W213 All-terrain
Maybe not enough space on your laptop...the Mercedes DLM first download on your HDD.
Anyhow, 4xx GB is far too much for such an operation
Old Oct 28, 2025 | 07:01 AM
NbyNW's Avatar
Veteran: Navy
Various
I've used this thumb drive a few times before for these updates with no problems. Interesting comment above about it may have to be a new drive, odd but interesting.
Has it worked for anyone? Maybe a problem on the MB website?
Old Oct 28, 2025 | 07:04 AM
trigital's Avatar
W213 All-terrain
You can try offline version of DLM
Old Oct 28, 2025 | 08:00 AM
NbyNW's Avatar
Veteran: Navy
Various
Might be a problem with NTFS formatting via my Mac, I'm using "NTFS for Mac" which has worked in the past. I think it's not seeing it formatted correctly as it says "Please format to NTFS..." ExFat doesn't work. Anyone with a Windows machine formatting to NTFS, what do you see here?
My S sees the drive and it works fine. I loaded an mp3 and it played it.
From the interwebs... UFSD_NTFS is a proprietary file system driver developed by Paragon Software. It is based on Paragon's Universal File System Driver (UFSD) technology, which allows operating systems to read and write to file systems they do not natively support.
Old Oct 29, 2025 | 01:02 PM
dmatre's Avatar
Has anyone had any luck downloading newest maps?
I've tried now with new USB stick and get same failure.
Checking the error log, it seems to be a JAVA validation failure of some type:
Old Oct 29, 2025 | 01:28 PM
Top Answer: 1
I got those exact same error messages when using a previously used USB stick. I even reformatted the drive a few times in hopes to solve the problem Problem was resolved when I used a brand new stick.
Old Nov 1, 2025 | 05:37 PM
NbyNW's Avatar
Veteran: Navy
Various
Big thanks to @carlosinseattle for suggesting a new drive. Crazy as it seems it worked. Ordered a five pack from Amazon and formatted to ExFat and it worked. Just have to load it to the car.
Old Nov 15, 2025 | 04:23 PM
dmatre's Avatar
Quick update: after trying everything else, I tried using a new USB drive formatted ex-FAT.
Download/update worked correctly with new USB.
Thanks to all here for the correct info.
Old Jan 8, 2026 | 08:25 AM
cdmotor1's Avatar
2019 Mercedes Benz S560 4Matic
Can anyone offer a link to get to this site? Appreciate any help offered!
Old Jan 8, 2026 | 09:28 AM
dmatre's Avatar
1st: Create an account at the MercedesMe website.
2nd: https://www.me.mercedes-benz.com/pas...?mapupdatevin= (add your VIN number after the '=' sign)
3rd: Follow instructions after that
Old Jan 8, 2026 | 09:38 AM
cdmotor1's Avatar
Thanks @dmatre . Clicking on that link gets this result:
Old Jan 8, 2026 | 02:29 PM
dmatre's Avatar
Did you create your account first? I just logged in and went' to the map update (which shows that my car is up to date) without problems.
