S-Class (W222) 2014-2020
Houston we got a problem… Weird heating behavior.
Old Dec 18, 2024 | 11:15 AM
Mookie1987's Avatar
2015 Mercedes-Benz S550 4MATIC, 2021 GLC300 4MATIC Coupe and 2006 S500 RWD
Is there a way to reset the Climate Control? When it is cold outside my car heats up well with both sides blowing hot air. When the outdoor temperature gets to like the 50’s-60’s Fahrenheit. the passenger side then blows out less hot and comfortable air. My driver side switched from hot to extremely cold and both sides are synced to 80f. It’s not hot outside it’s now 60f so why does the passenger side blows lukewarm comfortable air to accommodate for the outside temperature change while the driver side just jump to extremely cold A/C. But if I turn the heat up a few degrees both sides gets back hot like it supposed to? Do y’all suspect the heater control valve flap for the drivers side is defective? I don’t have a coolant leak.
Old Dec 18, 2024 | 05:59 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Would need to check actual values but either that side temperature sensor or heat blend flap has a problem.
Old Dec 18, 2024 | 06:13 PM
Mookie1987's Avatar
How do I pull up the data? Is it a way to pull it up on the display screens or do I need some kind of special diagnostic reader?
Old Dec 18, 2024 | 06:31 PM
VII's Avatar
VII
You are going to need a diagnostic device, thinkdiag is a good inexpensive option.
Old Dec 18, 2024 | 06:38 PM
Mookie1987's Avatar
Ok thanks I’m going look into getting one
Old Dec 18, 2024 | 10:05 PM
Mookie1987's Avatar
https://a.co/d/hVC8AMm
Is this a good one?
Old Dec 18, 2024 | 10:34 PM
VII's Avatar
VII
Same brand so I think that should work, I got one that works with the phone that was like $100. And with Amazon you can always send back.
Old Dec 18, 2024 | 11:49 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
If you really want to do this you need Xentry and Benz Ninja or you can learn how to operate the Xentry system.
I will say that when the temps go to 50-60 the system really does not know what to do.
I usually keep mine at 75dg in the winter.
Mine heats up so nice when its cold, but when its like you describe the system blows coolish air out and actually makes me chilly.
My S430 did the same thing.....
May be a Benz thing.
