S-Class (W222) 2014-2020
Misfire on Cyl 4
Old Jan 23, 2025 | 06:27 PM
vinflouen's Avatar
2019 W222 S560 4Matic/2025 Yukon Denali
Misfire on Cyl 4
Hi All,
my 2019 s560 (4.0tt) got a misfire on cyl 4.
car has 91k on it.
started it up to leave the office and it sounded like an AMG.
Shook very badly when I gave it gas (load)
drove it home (very light on the pedal)
Shut the car off for a while, no misfire.
ran xentry, cleared codes.
Took the car out again, no misfire.
it has also been under 10dg here for the last week….
where do I start my diagnosis?
Old Jan 23, 2025 | 07:19 PM
Baltistyle's Avatar
'13 s212 63 p30. '06 LX470
Originally Posted by vinflouen
Hi All,
car has 91k on it.
A weak coil pack could start to be flaky in cold weather.. if you’ve not replaced them with 91,000 miles, it’s definitely time to do those and the plugs, and you can boroscope the cylinders while you’re in there. You can look at injectors in xentry, but if you’ve never run any Techron or redline through it, it’s probably a good idea too.
Old Jan 23, 2025 | 07:27 PM
vinflouen's Avatar
thank you.
i did the plugs at 50k and was planning on doing them in the next month.
i run bg44k every 6 or so months.
I also try to fill up with sunoco 94.
tuned with Renntech (over 2 years with the tune)
Here is the readout from xentry
thanks for the feedback.
File Type: pdf
Old Jan 23, 2025 | 07:43 PM
blackbullit's Avatar
2013 ML350, 2019 S560
Hi All,
car has 91k on it.
Sounds like a bad coil. I have had 2 coils go on my S560. Took some time to each to fail. They behaved just like yours. You don’t want to wait. When one of mine failed completely, the ride to the Indy shop was not fun. Temperature didn’t seem to matter for me in Florida.
Old Jan 23, 2025 | 08:11 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
I’m betting it’s a coil on it’s way out.
Ww suffered the same issue (intermittent misfire for about a week before total failure) in our W212.
Best to change all of them, as the others will likely be failing at intervals going forward.
Old Jan 23, 2025 | 08:57 PM
vinflouen's Avatar
Thank you all.
I am going to get me 4 coils tomorrow and I guess it will be another weekend of 'fixin'.....
plugs and coils.....
I have NGK plugs....you have any opinion of them over the OE MB plugs?
Old Jan 24, 2025 | 07:26 AM
dlafever's Avatar
'15 S550, '10 E350 P1/P2, '02 ML320
Yeah +1 on the coils. I had my #7 fail and it took several instances of the misfire for it to actually store a code! Finally got the Check Engine light and the resulting code.
*ALSO: If I stopped and turned the engine off and waited 30 seconds it would start and drive like nothing was wrong, until it happened again. No problems in 15k miles since changing all the coils.
Old Jan 24, 2025 | 07:43 AM
DaveW68's Avatar
Veteran: Army
2015 S550
Thank you all.
Stick with OEM plugs, which I believe are Bosch.
Old Jan 24, 2025 | 10:08 PM
vinflouen's Avatar
Went to the dealer today and got 4 coils and 8 plugs...cost was $1100 for all....not bad at all!!
Old Jan 24, 2025 | 10:10 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Inspect the plugs individually and control the electrode gap without stressing center pin.
Old Jan 25, 2025 | 03:45 PM
vinflouen's Avatar
all done.
4 new coil packs, 8 plugs….
car runs perfect now.
check out the plugs.
42k miles on these.
photo taken as if from front of the car.
look at the 2 plugs with oil on threads….
no leaks visible.
Old Jan 25, 2025 | 06:20 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
I'm going to do mine next week, hope there's no oil on any of them! BTW, did you have to disconnect and take out a high pressure fuel line on the left side? That's mentioned in a video I watched on doing plugs on the 4.0 liter engine ...
Old Jan 25, 2025 | 06:47 PM
vinflouen's Avatar
im at 91k, gaskets are due soon but Im surprised at the oil on the threads.
You have to disconnect the battery so the fuel pump is not running, and then disconnect the fuel line on the left.
You cant get the coil out with the fuel line in place.
also on right side, in the back there is another t25 that you have to take off to remove some silver tube to get at that coil.
i had 2 stuck boots….one of them took almost an hour of pulling on to get it out.
all other bolts are 10 and t30.
torque plugs to 23nm.
Old Jan 27, 2025 | 10:27 PM
vinflouen's Avatar
Hi All,
I drove about 200 miles so far and no issues.
thank you all for the input.
new plugs and coils and it feels so good!
will be back asking about valve cover gaskets soon die to oil on cyl 2/3 plugs…..
Old Jan 27, 2025 | 11:41 PM
Hi All,
congratulations, well done!
Speaking of oil forced out to leak where possible:
Have you check CPS for oil??
Old Jan 28, 2025 | 12:47 PM
CPS? Cam position sensor?
Old Jan 28, 2025 | 01:26 PM
vinflouen's Avatar
I think i overfilled by .5l, so maybe thats my issue.
only 2 plugs (cyl 2/3) had oil on the threads.
Old Jan 28, 2025 | 04:42 PM
CPS... $10k oil leak
yes, camshaft sensors located on engine top at the front... frequently leak oil into whole engine harness ($10k repair).
Easily inspected by unplugging connector while ECU is asleep to prevent fault code.
Old Jan 30, 2025 | 02:46 PM
Have seen that discussed for the M278 engine, does it affect the M176 also?
Old Jan 30, 2025 | 06:28 PM
vinflouen's Avatar
I dont think so, that seems to be a wiring harness.
this motor 176 does not have it.
also get yourself a radio removal tool in case a rubber boot breaks away from the coil pack when you are pulling it up.
Dielectric grease on spark plug tips are a must.
Old Jan 31, 2025 | 08:47 AM
What is a radio removal tool?
Old Jan 31, 2025 | 11:31 PM
vinflouen's Avatar
Amazon Amazon
