S-Class (W222) 2014-2020
Blower motor.
Old Feb 10, 2026 | 12:12 AM
JohnLane's Avatar
222 S-65
Blower motor.
Having taken care of the coolant leak into the cowl I take her for a test drive. Back out of the driveway with ambient of 82 degrees. Ummm... why is the blower motor slowing down, speeding up... Turn off HVAC and turn back on... Now blower motor starts to growl. We know what this is.
Parts at MB stocks them. Replace as blower motor and controller.
WIS procedure starts with remove glove box. No need. Remove panel over pax side legs. Three small torx fasteners. Unplug electrical connector to lamp over pax feet. Blower motor is held in with five of same size fasteners. You will need a mirror and flashlight to see them. Unplug connector to blower motor. It wiggles right out. Controller attaches to blower motor. Blower motor plugs into controller.
Reassembly is reverse.
Hour of work start to finish.
Works great.
Original blower motor made it eleven years and 156,000 miles. Can’t complain.
Old Feb 10, 2026 | 10:07 AM
SSBN629 Seattle's Avatar
Currently ‘2015 S550 4matic. Previously 03 E320, ‘06 S430, ‘08 S550 4matic
Works great.
Great!
I always love the work arounds that forum members share with the group.
This may be a stupid question but what are “pax side legs”
thanks
Old Feb 10, 2026 | 02:20 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Originally Posted by SSBN629 Seattle
Great!
thanks
“pax side legs” = Passenger side legs
Old Feb 11, 2026 | 08:36 PM
Alexie's Avatar
Works great.
Nice. Eleven years and 156k is a solid run. Sounded like the controller was failing first then the motor started complaining. Good call on doing both at once. And yeah, you really don’t need to pull the whole glovebox just the knee panel. Five Torx and it’s right there. Mirror trick is key. Hour well spent.
Old Feb 12, 2026 | 12:54 AM
JohnLane's Avatar
222 S-65
Once out it is obvious bearings in the motor had packed it in. New blower smooth... silent.
If bad things happen in threes I should be done for a while!
Old Feb 14, 2026 | 07:58 AM
MBNUT1's Avatar
2010 E350 4Matic
I am thinking that I have read that the blower motor can be cleaned and lubricated back to quiet. Not true?
Old Feb 14, 2026 | 12:59 PM
I suppose you could try it for grins and whistles..
Old Feb 14, 2026 | 01:47 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
I tried to rehab the fan in the wife’s W212 - no joy.
You can’t get to the bearing, and spraying silicone lube at both ends of the shaft silenced the squeaky fan for about 10 minutes.
Old Feb 15, 2026 | 08:30 AM
JohnLane's Avatar
222 S-65
Juice isn’t worth the squeeze; esp when living in a climate where not having operational Heat or A/C can be life threatening. Also... once bearings are worn to making the blower motor audible no lubricant will help those bearings (that are clearly not meant to be serviced) live long enough to be worth the effort. I imagine the electric motor is also equipped with brushes that have to be at the end of their life too. A worn out motor may draw a lot more amps. Decades ago when I got to replace them in Volvo 240s by the time the blower motor was done the heater resistor and often wiring to it were cooked.
The tray the blower motor mounts to is included with the replacement MB blower motor. Remove one torx fastener that retains blower motor controller from the old blower motor and install new blower motor controller.
One torx driver, mirror and flashlight are only tools needed.
Old Feb 15, 2026 | 01:53 PM
JohnLane's Avatar
222 S-65
Removed two more torx screws on old blower motor to verify that brushes and commutator are worn.
Plain bushings that are bearings are sticking to the shaft.
Yup; not serviceable.
Old Feb 15, 2026 | 05:37 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
Well, that blows! Sorry, couldn't help the dad joke.
Old Feb 15, 2026 | 08:32 PM
C280 Sport's Avatar
MB’s of all kinds.
Did you go with a Genuine MB Part or something you found online? Just curious as I did a blower motor in my 2012 E. I went with a cheap aftermarket online one and it worked great as where MB wanted like $275 for the part.
Old Feb 15, 2026 | 09:16 PM
JohnLane's Avatar
222 S-65
I got OEM. Blower motor made by Behr so there may be a good aftermarket alternative.
Old Feb 16, 2026 | 01:47 PM
Top Answer: 1
If you can easily access the bushings and want to experiment with swapping the bushings, just for kicks and giggles, let me know. I have tons of bearings leftover from my RC days and might have some that will drop right in. Again, just out of curiosity.
Old Feb 16, 2026 | 03:09 PM
JohnLane's Avatar
222 S-65
Stamped steel housing shaped around bushings such that they are not coming out. She's not serviceable without going to extra innings. Commutator is worn such that there can't be that much more copper for brushes to conduct electricity to.
Old Feb 16, 2026 | 03:10 PM
JohnLane's Avatar
222 S-65
Originally Posted by Streibensie
I've seen tons of posts about these going wrong on the 221s and R230s. What did the blower cost?
$350.00 over the counter give or take.
Old Feb 16, 2026 | 06:09 PM
Thanks Carlos..
I heard a long time ago that while no question is stupid, there ARE stupid people who ask questions. Mea Culpa
Old Feb 16, 2026 | 10:26 PM
JohnLane's Avatar
222 S-65
Thanks Carlos..
Not stupid. You just didn’t know and asked. Now you know.
