21” tires and wheels
Old 12-10-2022, 06:47 PM
  #176
rds112's Avatar
W223 400d Long
Originally Posted by Baloo588
I also wanted to point out that the new s63 AMG has 21 inch rims but the tires are thicker
255/40r21 front and 285/35r21 rears compared to 255/35r21 and 285/30r21 on the regular s. Not sure why Mercedes did that and went with the thinner tires on the regular s but given this, you can upsize the tires without any rubbing..
good news! what about speedo after doing change ?
Old 12-10-2022, 07:30 PM
  #177
Baloo588's Avatar
Good thing it will be 3.4% slower which isn't too bad. I've done it on my Lexus and BMW in the past and had no issues. 60 mph on the upsize tire vs 62 mph on standard etc isn't bad.
Old 12-15-2022, 08:16 AM
  #178
rds112's Avatar
W223 400d Long
I know its 3.4% but the thing is, that it will not only affect speedo.
Odometer reading will be not correct.
Fuel usage will be not correct.
Gearbox shifts will occurs in different speeds.
Also there is something called homologation. In europe insurace can block paying you your money because you did not used tires homologated for that vehicle.
I'm wondering if you can change it in service computer.
I'm really interested in that since I've changed my 21" to 20" but kept 21" in garage. They look so good, and maybe with fatter tires, they could match 20" comfort.
Old 04-12-2023, 11:11 PM
  #179
JorgeSand's Avatar
2007 S550/2010 tail lights smoked/2W010 LED DRL/22' staggered Maya wheels
Originally Posted by sjdille
An exact replica of what happened to me. On my first pothole tire failure - I had my second yesterday - I blew my front tire and the rear behind it had a bubble. Had to replace 2 tires. No run flat tires so I limped home and had the car towed to Mercedes the next morning. Got my car back this morning after my second pothole failure yesterday. These 21” low profile tires WILL NOT survive even small pot hole impacts if hit in a certain way. Now I’m so gun shy, my eyes are glued to the immediate road surface ahead instead of focusing on everything else.
It sure takes away much of the pleasure of driving my new $140,000 + car. And, believe me, this will happen to many more new S580 owners with 21” wheels and tires.
hi, just got this vehicle 2 months ago & experienced 2 flats then. Was wondering if you had any suggestions (other than going 19 or 20). Maybe a thicker tire…255/40/21? Not sure if that would work….
Old 04-12-2023, 11:12 PM
  #180
JorgeSand's Avatar
Were these Pirelli on 21” wheels?
I have filed a safety complaint with NHTSA as to my tire - 3 - failures with this set up. It would be a good idea for those with the same failures to call the NHTSA Hotline and lodge a complaint. Reading on this Forum, there are many more of us with these tires blowing out. The more complaints NHTSA gets, the quicker s recall may happen.
This is a serious safety issue and these tires need to be replaced ASAP
2 tire failures within 2 months of having this vehicle. With the 21. Shoot the # & will call
Old 04-12-2023, 11:14 PM
  #181
JorgeSand's Avatar
hi, just got this vehicle 2 months ago & have experienced 2 flats since then. Was wondering if you had any suggestions (other than going w 20). as you did). Would the thicker tire work??
Old 04-12-2023, 11:16 PM
  #182
JorgeSand's Avatar
Originally Posted by ColeBlooded
Possibly for ride comfort since I'm sure the AMG variant has stiffer suspension.
For those of you with blown 21s, you could always try a higher profile tire since the 63 can fit them.
do you think that would trigger something on the computer? I’ve had 2 blowouts in 2 months…was thinking of doing this
Old 04-12-2023, 11:21 PM
  #183
JorgeSand's Avatar
The Michelins have few thousand miles already on them and they have firmed up nicely while giving a great ride. They handled the choppy and some uneven roads without any blowouts so far.
the sidewalls are more beefier looking then the Pirellis and look thicker overall.
have these tires held out better since your purchased them??
Old 04-12-2023, 11:32 PM
  #184
sjdille's Avatar
2020 Tesla S
I would guess you had 21” Pirelli’s that failed. My three failures were and so are dozens, maybe hundreds, of others reading earlier posts on this thread and talking with two different Mercedes service advisors. If you don’t want to change to 19” or 20” wheels, put on some Michelins.
‘BTW. I have received no response from the NTSB on the complaint I filed months ago about this safety hazard!
Old 04-13-2023, 08:57 AM
  #185
jsoloddss65's Avatar
'23 S580 Manufaktur and '21 GLE 53 Coupe (Past MBZ: 2020 GT63, S65, S63, E55, CL65, S550, C32)
My fears about the 21’s came true after 2000 miles. This is the passenger front tire. I am glad I check the tires often with the known problems. I had a wait a week for a tire. I have no clue how it happened.
Old 04-13-2023, 12:39 PM
  #186
Baloo588's Avatar
They are much better than the pirellis. I did swap out to the 20s and using Michelin Pilot sport all season tires as I drive alot on highways. I still highly rec the pilot sport 4s for those who have the 21s as it's smooth and quiet.
Old 04-18-2023, 12:51 PM
  #187
KianFoster's Avatar
Lexus
Hey there! Choosing the right tires and wheels for your car enhances its performance and style. If you're looking for top-of-the-line forged wheels, check out COR Forged Wheels. They offer various custom wheel options with premium materials and finishes. Plus, their wheels are designed and engineered for maximum strength and durability, which is especially important for high-performance cars.
Old 04-19-2023, 12:06 PM
  #188
DonS550's Avatar
2021 S580 (current), 2019 S560, 2018 S450, 2015 S550, 2010 S550, 2006 S500.
Wow, I've not had this problem yet and I drive 21" wheels on my 2021 S580.
Old 04-19-2023, 12:08 PM
  #189
sjdille's Avatar
2020 Tesla S
Do you have Michelin or Pirelli tires?
Old 04-19-2023, 10:13 PM
  #190
JorgeSand's Avatar
So I finally got the Michelin Pilot Sports 4S mounted and road force balanced on my S580 21s and its worlds better than the Pirellis. More smoother, quieter and far better over bumps and dips in the roads. No vibrations on highway etc. Pirellis have this weird vibe in the chassis on highways which Michelins do not have. Michelins feel like you are on cloud. The steering is more precise and more heavier now.
As you can see in the pics, the 4S is more beefier looking then the Pirellis. I have not had any blow outs, puncture, etc with these tires on any of my cars since 2018 when the 4S came out. I usually get 35k miles on a set so about 3 years since I always switch my wheels/tires to winter set from Nov to March. Lots of people over on the Audizine forums with the new RS6 and RS7 have not had any issues with their low profile rims and these tires in size 285/30R22s.
hi, i just got 255/40/21’s in the front. Is that the same size you got for your front tires? How has it been? No blowouts since?
also, the rear the s580 comes with is 285/30/21. Did you go up to 285/35/21 or did you leave the 30s? If so how does it ride with either or?
Old 04-19-2023, 10:31 PM
  #191
JorgeSand's Avatar
Originally Posted by odesskiy
Just got shuttled to the dealer to pick up my loaner while waiting for a replacement tire for the one I blew on Saturday. The service advisor tells me “hey, take a look right over there”. And there’s yet another S580 with a blown 21” Pirelli. I even snapped a pic of it. Looks like the owner drove it for a bit to get away from wherever it happened. The rim is wrecked too.
The service advisor told me that the problem is so widespread that no one is surprised anymore when these come in. His exact words were “this should be a class action lawsuit”. So please, please, please if you’ve experienced this problem, go read my thread and send me the info. I want to get the ball rolling with MB corporate ASAP. If all we do is ***** on the forums, nothing is ever going to be done about this.
Here’s another unfortunate soul at the dealer.
any luck w this class action? Got someone here who can join in on the pot! 2 blown Pirellis in 2 months
Old 04-19-2023, 10:33 PM
  #192
JorgeSand's Avatar
I changed the front to 255/40/21 but left the rear 285/30/21. Do you think this will be an issue?
Old 04-20-2023, 09:12 AM
  #193
sjdille's Avatar
2020 Tesla S
NHTSA vehicle safety hot line is 8883274236
Old 04-20-2023, 09:32 AM
  #194
sjdille's Avatar
2020 Tesla S
Per my previous posts, I’ve had 3 blowouts with 21” wheels/Pirelli P Zero tires. Service managers at two different San Diego MBZ dealers say there have been dozens more with this combination. Mercedes does nothing about it. My complaint to the NHTSA months ago …no action! (BTW the hot line for safety complaints is 888 3274236 and maybe a slew of calls to them may force them to do something)
I’d sure be willing to join a class action suit against MBZ and/or Pirelli. The combo of super low profile 21” wheels and a tire with a “too thin and too flexible sidewall” like the Pirelli P Zero is a time bomb. And that bomb has already gone off for too many of us!
Old 04-20-2023, 11:53 AM
  #195
SW20S's Avatar
Received 2,801 Likes on 1,795 Posts
2024 S580
Honestly? I would just buy Michelins to replace the Pirellis if you have this issue. The cost of my time trying to file lawsuits and complain to the NHTSA is worth more than the cost of a set of tires.
Old 04-20-2023, 12:27 PM
  #196
docsout's Avatar
2023 S Class 2013 SL
So…., explain to me again, why RR can have 22” tires and provide a great ride while MB is plagued with narrow sidewalks that fail?
Old 04-20-2023, 12:46 PM
  #197
sjdille's Avatar
2020 Tesla S
Of course change Pirelli to Michelin, which I'm doing. My point is for those that have not, it is a major safety issue that needs to be addressed by MBZ and Pirelli. There is simply too much flex in the P Zero sidewalls and when the super low profile 21" wheel and Pirelli combo hits an obstruction or pothole, many fail. Seems not so with Michelins. Either MBZ or Pirelli needs to address this situation before an injury or worse happens.
varun16 (04-26-2023)
Old 04-20-2023, 01:13 PM
  #198
SW20S's Avatar
2024 S580
Originally Posted by sjdille;[url=tel:8763115
8763115]Of course change Pirelli to Michelin, which I'm doing. My point is for those that have not, it is a major safety issue that needs to be addressed by MBZ and Pirelli. There is simply too much flex in the P Zero sidewalls and when the super low profile 21" wheel and Pirelli combo hits an obstruction or pothole, many fail. Seems not so with Michelins. Either MBZ or Pirelli needs to address this situation before an injury or worse happens.
You have more time and energy than I do lol. Not trying to save the world today.
Old 04-20-2023, 02:16 PM
  #199
Baloo588's Avatar
It could be a bit confusing for the 4matic. I highly rec putting 285/35/21 rears to keep it even as the s63 comes with 255/40/21 fronts and 285/35r21 rears.
Old 04-20-2023, 05:25 PM
  #200
ColeBlooded's Avatar
S580
If you mean Range Rover, those have a 45 or 50 aspect ratio.
Quick Reply: 21” tires and wheels
