Same dealership, similar response.
Old May 12, 2025 | 08:38 PM
  #51
Sparky66's Avatar
W167 2021 GLE63S, W223 2022 S580
48V
I can't remember what a 48V battery should be a full charge as you already know a 12V battery at full charge is way higher than 12V so I assume the principle is the same? I saw that image but isn't 71% at 47V a bit low?
Fairly certain the 48V battery is Li Ion and not AGM and normal max is 80%
Old May 12, 2025 | 09:16 PM
  #52
TheBlackPanther's Avatar
2021 S580
I just drove around for a bit after seeing this thread for the last couple of days...a little combined highway/side road type driving...15 miles or so...during this time on the workshop/vehicle data menu I had a low of 45 volts to a high of 50 volts, charge status from a low of 63% to a high of 76%, amperage from a low of -113.3 A to a high of 206.0 A (the highs of 50 volts, 206.0 A with a charge status of 76%, temp 101 degrees were reached coming off a highway speed of 92 MPH a few seconds after moderate braking coming down a long offramp.
Old May 13, 2025 | 11:35 AM
  #53
retatt's Avatar
Veteran: Army
After 2 hours of interstate driving 12volt battery was as 12.38 volts at rest. I’m assuming it should be about 12.8 volts.
Old May 13, 2025 | 03:21 PM
  #54
W205C43PFL's Avatar
Fairly certain you are right, although in MB's case even the AGM is not charged to max charge.
Old May 13, 2025 | 03:22 PM
  #55
W205C43PFL's Avatar
Hmmm might still be a little low.
Old May 13, 2025 | 03:24 PM
  #56
W205C43PFL's Avatar
Appreciate you for posting.
