Adaptive Highbeam Assist
The highbeams definitely shut off with oncoming cars (instantly) and perfectly sense coming up to another car from behind and shut off at the proper time. Glass/windshield is definitely clean...not fogged up or anything like that. Dealer confirmed software up to date, no codes, and headlights are perfectly adjusted. I thought the issue might be a bad ambient light sensor in the multifunction camera, and fought with the dealer who eventually did replace the camera under warranty (and initialized/calibrated the new camera). No change at all. Highbeams still coming on and off seemingly too much.
A couple months back, the dealer gave me a 2025 GLS for a loaner and the Adaptive High Beams seemed to work perfectly (on the same road/same conditions as I drove my car).
Anyone have a similar experience with the Adaptive Highbeam Assist? Any solution?
I see how this can be very bothering.
If the W223 coding were cheaper like on the BMWs, ($200+), I would've done the coding.
I did extensive nighttime driving on country roads over the weekend and it made me want the feature a LOT more than I anticipated.
Auto high beam switching to low beam just cut the top lighting off and it was a huge difference in visibility.
If it had the ILS+ feature it would've been a lot more enjoyable driving at night.
THANKS
THANKS
Also, a huge shoutout to Steve for his guidance and for pointing me to the correct adapters on Amazon to buy. Because I live in a larger city, I ordered and received them same day. Both adapters were less than $30.
ODB Adapter $13.99 - Ethernet to USB adapter $15.99 -
ODB Adapter $13.99 - https://www.amazon.com/dp/B0CBTCKDQX...fed_asin_title
Ethernet to USB adapter $15.99 - https://www.amazon.com/dp/B087QFQW6F...fed_asin_title
