HUD Inoperative
Old Dec 8, 2025 | 08:57 AM
Sparky66's Avatar
W167 2021 GLE63S, W223 2022 S580
HUD Inoperative
After multiple visits to the dealer and software updates I still get the random HUD inoperative - consult workshop message. Any chance someone knows the TSB or Xentry Tips and will share? I found the one for the 167 but I have been unable to locate one for the 223
Old Dec 8, 2025 | 09:17 AM
Petersla's Avatar
2024 AMG GLE53
following - I've been cursed with this since the beginning with no joy on resolution. I also get a blurry, ink stain sort of image at times.
Old Dec 8, 2025 | 10:35 AM
Sparky66's Avatar
167
Here is the one for the 167 attached
File Type: pdf
Old Dec 8, 2025 | 11:18 AM
Petersla's Avatar
2024 AMG GLE53
Thanks for supplying this.
Mine has been in several times (5 - 6) for this and even has had the HUD replaced (requiring removal of the dash). If there has been a SW update since 2020 (if I am reading that correctly) and my dealer hasn't done it, I will be pretty cranky
Old Dec 8, 2025 | 01:38 PM
Alexie's Avatar
On the 223, the random HUD inoperative message is almost always a failing projector unit itself. The solder joints on the internal power supply crack. Common TSBs are LI54.10-P-063130 and LI82.10-P-060798. The official Xentry tip is to replace the HUD unit (A222 900 13 01), as repairs to the internal PCB are only temporary. Check for stored fault codes in the actual HUD control unit (N123/2), not just the central gateway. If you see codes like 9101 or 9102, it confirms the internal fault.
Old Dec 9, 2025 | 11:17 AM
Sparky66's Avatar
Thank you for the information. I forwarded this to the SA and will update this thread when resolved (hopefully)
Old Mar 5, 2026 | 03:18 PM
Sparky66's Avatar
HUD replacement
Got notification that MB authorized the replacement of the unit. Now awaiting the unit's arrival. I will update in the future if replacement of the unit resolves the issue. Thank you for your post as I shared it with the SA.
Old Mar 22, 2026 | 10:28 AM
Sparky66's Avatar
Not the HUD unit
HUD unit was replaced and the new unit did not rectify the issue. Unfortunately the saga continues...
