Consume 1qt. of oil every 1K mile?
Old Aug 2, 2010 | 04:34 PM
gripforce-cl65's Avatar
Fast cars in general....
So far, I've put about 2K miles and it looks the motor is consuming 1qt of oil in every 1K mi.
I know the 65 motors consume oil, but I don't think it consumed this much. Is this normal??
BTW, the typical MB dealer says it's perfectly a 'normal'
Old Aug 2, 2010 | 06:03 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
All manufacturers say 1 qt of oil per 1K mile in normal. I would check for leaks under the car and around the gaskets to identify the source, otherwise it is just burning the oil along with fuel. Check for black smoke on start up or heavy acceleration, etc.
Old Aug 2, 2010 | 06:16 PM
No leaks under the car and around the gaskets.
No noticeable amount of black smoke on start up or under full throttle.
Old Aug 3, 2010 | 12:27 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
oil consumption will be a normal thing for the that engine for it's entire life, for the first 5000mi expect the oil consumption to be as high as that, it will drop off after the piston rings bed in fully. Just don't baby it while it's new, it will just take longer to bed in.
Old Aug 3, 2010 | 09:43 AM
GFEAR's Avatar
That's normal for the ttv12
Old Aug 3, 2010 | 10:11 AM
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
I would say 1 qt every 2K miles was the "norm" for my CL65. I also used to do my oil changes every 5K miles since I had the engine tuned.
Tom
Old Mar 6, 2012 | 10:07 PM
Saeedg48's Avatar
2009 CLS63 AMG
i've filled my car up with a total of three QT. i've checked the dip stick the light came on for the first two but i figured i'd check it myself the last time around.
i have a total of 7,200 miles. so 7200/3 = 2400 miles.. sounds about right. my m3 burns so much oil :/ and at $13.50 a quart it gets annoying.
Old Mar 7, 2012 | 09:53 AM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
My S65 uses about 1qt for 2K miles. My previous '03 S600 hardly used any oil in comparison. Maybe 1qt per 5K miles.
Old Mar 7, 2012 | 11:37 AM
Oxygen's Avatar
W220 S65 AMG
I have to agree with everyone else here, I am looking at about 1qt for every 1,500 miles or so.
Old Mar 9, 2012 | 01:59 AM
falconsprint's Avatar
2001 Lamborghini Diablo, 2009 SL65 (sold), 1998 CL600 (sold), 1989 560SEL (sold)
Same here, about 1qt every 1500 miles.
Old Mar 11, 2012 | 04:30 PM
Vabene7's Avatar
Garage Temporarily Empty
My S600 uses a quart per 2k miles.
Old Mar 12, 2012 | 06:44 PM
Viet_Amg408's Avatar
Pinto
try thicker oil see if it makes any difference
Old Mar 27, 2012 | 01:46 AM
w4sim's Avatar
S55K AMG
That possibly wont be the best thing to do in my opinion, you should use the recommended grade of oil. In my 2004 S55k its 0w40. I always use that.
But i think my average oil consumption is about 1200 miles to 1 litre. I spoke to my indie who said "considering its a big V8 that has a supercharger fitted to it, 1 litre per 1000 miles is pretty normal so dont worry about it".
Iv pretty much accepted it as that and have not questioned it again, on the plus side iv also come to realise that every time i top up with that 1 litre of oil when the car tells me to, the distance between the next service goes up a little bit.
The last time i had 4,700 miles till the next service, message came up on dash telling me to add 1 litre of oil, the next time i checked the service indicator after the top up it had gone up to 5,200 miles till next service.
Old Apr 13, 2012 | 10:18 PM
300SDLguy's Avatar
04 CL & S600 designo Espresso's
One uses oil, one doesn't
My 04 S600 with 30K miles doesn't seem to ever need oil added between oil changes, on the other hand, my 04 CL600 with 60K miles, needs 1 qt. every 1000 miles normally. The dealer stated it was in the "normal" range of oil consumption for the V12's.
