2011 s63 exhaust upgrade
Old Oct 6, 2013 | 11:10 AM
1bad63's Avatar
S63
Anyone running Renntech headers? I'm curious to know if it gave better sound
Old Oct 7, 2013 | 05:55 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Adding any headers will increase and change the sound some. The larger the header (IE long tubes), the sound will get deeper and louder. Removing the rear resonator will add some to the sound, if you are looking for an easy fix.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 7, 2013 | 05:59 PM
1bad63's Avatar
S63
How do you remove resonator
Old Oct 29, 2013 | 06:52 PM
iyad.2010's Avatar
E55 AMG W211
go 2 the exhaust shop and tell them i want to delete my resonater
and put a straight pipe
Old Oct 30, 2013 | 09:56 AM
dcm95ss's Avatar
c63, '65 buick riviera, '65 impala, s63
Will a secondary car delete throw a code ?
dcm95ss's Avatar
Cat
Old Nov 15, 2013 | 11:52 PM
bobbyjames's Avatar
2010 S63 Kleeman Longtube Headers, Deleted Cats, Weistec ECU Tune
I have a set of Kleemann long tube headers. The resonator and cats are deleted. It is obnoxiously loud, really loud! It scares women and children when I start the car or rev the engine. Ill post a video later
Old Nov 15, 2013 | 11:54 PM
bobbyjames's Avatar
When I had the ecu tuned they removed the codes during the tune so it does not cause the check engine light to come on. It will pass inspection with the cats deleted.
