V12 fan shroud
I know my S600 ain't an AMG but I imagine all V12 220 bodied cars are the same for this. So, I popped for the Speedriven idler pulleys (nice stuff) and went to install them today but ran into an issue right off the bat. Unlike my old S55 its VERY tight in there. Looks likes in order to remove the fan shroud I will need to remove the drivers side radiator hose as well as disconnect the passenger side tranny cooling line in order to clear the lower support pegs on the shroud coming out the top: is this correct? I'd like to avoid any dis-assembly that isn't needed but looks like that is what it takes.
If yes, how does the radiator line come off at the radiator? It looks like the hose is clamped to an elbow that is fitted to the radiator itself. Does the elbow come off? How? It looks likes it needs to for the shroud mount peg to clear. Thanks in advance for advise, preferably from one of you who's "been there done that". I gotta get off my ass and get the WIS for this car |
call/pm speedriven. they should know the answers if it didnt say in the instructions
Originally Posted by richvegas
(Post 6005536)
Actually, I should be able to figure it out, just wanting to make sure I actually have to disconnect the two lines and I don't want to break anything. Once the shroud is out of the way releasing the tensioner and replacing the pulleys is a piece of cake. |
No, you don't remove the radiator hose, you just disconnect the upper tranny cooling connection; no biggie. Its not the shroud you take off, its the whole fan assy, starting with the 4 pin electrical connector.
Its not easy, it takes a lot of manipulation and a lot of care and not a little force at times. Facing backwards, you lift the left hand end of the fan assy first, and tilt it about 30 deg to clear the rad inlet. Get a good light, take your time and take care. Nick |
Originally Posted by Welwynnick
(Post 6005694)
Its not easy, it takes a lot of manipulation and a lot of care and not a little force at times. Facing backwards, you lift the left hand end of the fan assy first, and tilt it about 30 deg to clear the rad inlet. Get a good light, take your time and take care. Nick Thanks, that what I thought might be the case, one side open and tilt it. Looks like the tranny cooling line is the easier removal. Plus I got the WIS from another poster on the 220 forum. Thanks again, I'll tackle it fresh tomorrow. |
All done! Disconnecting the tranny cooler hose was the key; then you can tilt it enough for the lower support on the other side to clear the hose without removing the hose. Smooth running mon!:)
It is double without removing the fan assembly, depending on what tools you have available. The only issue is getting that dust covers off the stock pulley. Other wise its a at home project. Even if you do remove the trans lines you don't lose much fluid and the job doesn't get to messy. Congrats on the install!
Originally Posted by Speedriven1
(Post 6007956)
