Lotsa work done today.....
Fluid (oil) is Mobil 1 JETOIL. One can will change the fluid twice. I ran for a week to flush then changed it again. A can was about $15 online.
I used a vacuum pump to remove the old fluid and a large syringe to install the new fluid.
Pretty simple actually. Put a rag/towel under the fill hole before you remove the plug so you dont lose it if you drop it. Use a "ball head" allen wrench. I also used some teflon tape on the drain plug when reinstalling to avoid leaks. Go for it.
