M113k Manual gearbox, standalone build thread.
We start a new project. Spent some time thinking of this and thought it was time. Engine is S55 AMG M113k V8 Supercharged with 6spd gearbox 716.667 oem clutch kit, f/w. Megasquirt ecu, custom mounts, driveshaft, modified manifolds and sway bar. Will update as I go
Engine test fit
Fits great
Transmission test fit on m113 engine
Going here
Still, a 5.8 manual v12 with tubular exhaust manifolds would be a nice experience.
The V12 has the same bell-housing interface as the v8.
Nick
Notwithstanding that, a V8 transmission will physically fit a V12. I know because I've tried it.
Nick
I'm doing a similar conversion. M113k engine in a 1974 opel manta. Did you wire the ECU yet? Are you going to be firing both spark plugs in each cylinder? I
m looking into a Haltech Elite 2500 ecu with 2 x HPI8 ignitors to fire the coils. I'm also keeping the original transmission
for everybody that message me if the project is still going forward... we are very close to completetion. sorry for lack of updates.
i have decided to use AEM Infinity 508 ECU.
has 8 injector output, DBW, and 8 ignition outputs. using AEM ignitors to fire booth plugs at each cylinder at the same time.
AEM has the 60-2 crank pattern that we need also. wiring is almost done. engine and trans is out of the car. mounts are done.
supercharger is removed to delete the supercharger bypass valve. we wount be needing that.
EGR valves are being blocked off with VRP plates
using stock throttle body (still need to decipher what the 6 cables mean)
using either the stock benz accelerator pedal or nissan 350z pedal.
also new BBK
and quick youtube video
I've been working out the wiring for the last month or two and I sent Haltech my wiring diagrams for the pedal and throttle body for the DBW system (diagrams attached).
This is their reply
"Hello Peter,
On the subject of your recent email. All connections outlined in your diagrams look proper. Are you having any issues or just checking before initial power-up?
Regards,Sales & Tech Support"
http://ww2.justanswer.com/uploads/eu...7_m16_diag.pdf
