2003 S55 Vibration???????
Old May 7, 2017 | 01:45 AM
AMGK1NG's Avatar
2004 clk55
The car hesitates from stand stills if im gentle on the throttle, has a vibration at 20-25mph,40-50mph and at 60mph those exact speeds i get a vibration sometimes light sometimes very heavy and shakes the whole cabin. What could be causing this vibration not throwing any codes.
Old May 7, 2017 | 07:55 AM
g60wall's Avatar
2014 E63s
Motor mounts.
Old May 8, 2017 | 06:24 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
Does it feel like a bad torque converter?
Old May 8, 2017 | 09:27 AM
AMGK1NG's Avatar
2004 clk55
I thought it was a bad torque converter, i dont know.
Old May 8, 2017 | 09:28 AM
g60wall's Avatar
2014 E63s
Have you even done motor mounts? I suggest you do the motor mounts first.
Old May 8, 2017 | 09:31 AM
AMGK1NG's Avatar
2004 clk55
I have done nothing, i ordered motor and tranmission mounts i just had another issue set me back, check my other post i have a coolant visit workshop message maybe you can help me with that to?
Old May 10, 2017 | 12:15 PM
cmpcpro's Avatar
2004 CLK 500
I am suspecting my torque converter.. I've owned four S classes, 2000, 2006, 2008 and 2010, the lowest mileage was 30k and every one of them had torque converters that didn't feel right.
Old May 11, 2017 | 08:01 AM
GrepAwk's Avatar
'03 S55 (79K miles)
I recommend changing the transmission mount if you want to try a quick fix. I had a similar issue that is totally smoothed out with a tranny mount replacement. It's easy to fix yourself and if it doesn't work, then you can step it up to engine mounts (at dealer if you are not a DIY guy).
Also check Automatic Transmission Fluid level. Low ATF can cause oscillations in the valve body or chatter at shift points, if you associate the vibration with shifts. (Though it Sounds like your issue is more tied to the RPM)
Old May 12, 2017 | 08:53 AM
AMGK1NG's Avatar
2004 clk55
Will get back to this post once i install the mounts.
Old Jun 5, 2017 | 09:12 PM
robunicu's Avatar
02 cl500, 04 sl55 AMG, 06 E55 AMG, 92 180sx,
transmission mount or drive shaft carrier bearing
