Tire sizes
Old May 14, 2017 | 02:49 PM
WillyG's Avatar
S55 Designo
Tire sizes
Currently I'm running stock wheels and stock tire sizes F245/45/18 R265/40/18. Was wondering if I can run a 275 without rubbing. This is on a 2003 S55. Thanks.
Old May 15, 2017 | 12:46 AM
E42AMG???'s Avatar
E420
Front 265 40 18
rear 295 35 18
this is on 2003 s55 stock rims stock height no issues at all could do 305 in the rear
Old May 15, 2017 | 07:58 AM
Welwynnick's Avatar
2006 S600
You can run 275 at the front if you want to!
Nick
Old May 16, 2017 | 12:09 PM
WillyG's Avatar
S55 Designo
Nick
Appreciate it. What size fronts do you recommend? R255/40 and 275/35?
Old May 16, 2017 | 05:28 PM
Welwynnick's Avatar
2006 S600
I would recommend 265/40 on 18 x 9 all round, or 275/40 on 18 x 9.5 all round. The offset needs to be 43mm to 46mm.
Nick
Old Jun 5, 2017 | 05:39 PM
98'clk320's Avatar
mercedes benz 98 clk 320
Idk if this helps anyone if u ever have a related issue to this,i was running a 275/40/18 ... could've gone 35* im lowered on lowering links and noticed when hitting bumps or on a rough street the door locks would unlock ,i couldnt find the culprit until i needed rear tires and replaced with 255/40 18 and never had the issue again ,I've researched its your module inside the trunk if u ever have door lock issues, some type of receiver, or the parking stick wiring might be reading it on park etc... but im glad i found this out if someone ever has this issue u will know where to check first before it turns into a wheres waldo game .
