ABC DRIVE CAREFULLY-01 s55 amg
Old Jun 10, 2017 | 08:06 AM
AMG.19's Avatar
2001 Mercedes Benz s55 amg
ABC DRIVE CAREFULLY displayed when on the way home from the beach, had to keep going knowingly that would switch to home mode and be able to make it. So pulled over realized it is leaking (back right control arm all wet). My question is to the best of knowledge did the system get the partials within itself therefore the abc system needs to be flushed and may always have a problem...
Old Jun 11, 2017 | 08:12 AM
Welwynnick's Avatar
2006 S600
Did you mean particles?
They would typically be caused by the pump failing, which wouldn't cause a leak. That's a different problem.
Nick
Old Jun 12, 2017 | 07:37 PM
mercar's Avatar
190E, C280, S55
If the leak is on the control arm, that probably indicates the struct is leaking. You may have to replace the strut.
Old Jun 13, 2017 | 04:19 AM
AMG.19's Avatar
Thank you mercer and welwynnick... looked into putting on springs, selling getting new one since mb was inexperienced on abc in beginning such a nice system when working so sad and costly when sitting...
Old Jun 13, 2017 | 06:22 PM
Welwynnick's Avatar
2006 S600
Please don't abandon ABC. It's only nuts and bolts, oil and rubber. Whatever is wrong can be fixed.
If you can describe what is wrong I can describe how to fix it.
Nick
Old Jun 14, 2017 | 09:07 PM
cmpcpro's Avatar
2004 CLK 500
I agree. The ABC is the best part of the car! Springs are a cheap fix on a 100k car
Old Jun 15, 2017 | 12:43 PM
AMG.19's Avatar
Back right tire had fluid all over it was soaked hydraulic fluid? what possibly is problem? if back right went back left is worn (need replacement)... that why she sitting until abc fix i buy same model newer throw rims on or sell. Ill let go off her for 4000 tommorow anybody want moderaterly clean 01 s55 amg brand new oil chang day before trip and coolant flush. engine pulls any other car on highway
Old Jun 15, 2017 | 12:46 PM
AMG.19's Avatar
you said strut but than i have replace other strut i just did front two control arms... back two now i just want her ship shape for me next owner... i like my mercedes able to drive treated me very well for a solid year no issue this is just something i knew was going to run into high mileage but i will pay for the enjoyment
