Water-Methanol Injection System for M275-M279 Engines
This system is a complete, bolt on system that can be installed with out any guess work or custom fabrication. Weistec has engineered and manufactured many of the components of this system to ensure a simple and straight forward installation that a universal kit simply lacks. The gains in performance and consistency make this system an essential upgrade for the M275 and M279 engines.
Key Features:
Reduced Intake Air Temperatures
Increased Knock/Detonation Resistance
20-80 HP Gain*
4 Ply Silicone Charge Y Pipe with integrated Injector Port
Vacuum/Boost Adapter
Water/Methanol Controller with built in MAP sensor
Weistec CNC Machined Injector Bodies with built in check valves
Small, Medium and Large Quantity Injection Nozzles Included for a wide range of configuration
Tank with Integrated Level Sensor (actual tank my vary from images)
Designed for 50/50 Water and Methanol Mixture
Compatible with Stock, and Upgraded Turbochargers
All hardware and gaskets are included
Please PM or Email for pricing and Info!
Mothman@Weistec.com
