76 vs 80 Pulley...
Old Dec 14, 2020 | 02:47 PM
Blachermeier's Avatar
2005 S55 AMG
76 vs 80 Pulley...
Now that my factory pulley is shot.. I’m looking to upgrade to a smaller pulley and tune. I only want to upgrade cooling at the most and not get into more than that at this point. Would you go with the clutched 76 or 80mm? I’d be using it daily in summer and only for short pulls when opportunities arose... not planning on tracking it or constant abuse..
I was also under the impression you want to stay away from fixed pulleys due to heat and drivability..? Not sure if that is true but wouldn’t mind the power at all RPM’s if it didn’t require additional mods or damage..
Old Dec 15, 2020 | 02:51 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
If you intend on leaving your vehicle mostly stock the 80mm would be the way to go.
Old Dec 16, 2020 | 02:17 AM
MartinWake's Avatar
CL55
The s class has 2 heat exchangers so send it and get a 76mm
