C217 MY17 Upgrades
2017 S63 Coupe (Roo); 2020 S63 Coupe (Dorian); 2021 Maybach GLS 600 w/all in 4 seat config (Bach S)
They squeak a bit when cold. Warm them up and you won't hear them. And, warming them up is FUN!
I love them, and you can't compare them to regular breaks. They have amazing stopping power.
Like the wise man said--lesson learned
The quality of the ride is the same (great) and the look is even better. Here it is in -6 (-8 is lowest)
Heisenberg (04-25-2019)
@thewb I'll get better lowered pics after Eastside Auto Salon does the de-badging and final application of Modesta this Sat
thewb (04-19-2019)
Dan,
could you tell me what the all in cost of the CCB upgrade was and were there any hickups on install or was it straight forward.
I had a 2015 S63 and am considering getting a 2019 but finding one with CCB's is nearly impossible, so i am thinking of this option.
Any advice would be much appreciated.
Dan,
The one snag was an unexpected time delay—an approval process from MBUSA for the upgrade, and some time to update their VIN Database with this change (so it’s all covered under warranty and recorded in case I ever sell Dorian, and the new buyer comes in for CCB warranty work).
I didn’t know about this process and it delayed the work by a week or more. In hindsight it makes sense to record, but I was surprised it needed approval. Also that it took so long to approve, record in their database and somewhere on Dorian. The computer system also needed reprogramming to work with the CCB.
Bottomline, Mercedes of Lynwood, WA did an outstanding job, and Garrett who oversaw the work also did everything right, paid attention to all details, and was a pleasure to work with! As said before, I Love the CCB experience, and it was well worth the money.
Next time I will get it from the factory during my next build :-). Far more cost effective. If like me you intend to keep the coupe long term, I highly recommend it. Otherwise I would consider a new build with everything you want and CCBs.
hope this helps,
Dan
#32
About $26K for the hardware and install. The job was perfectly executed.
hope this helps,
Dan
hope this helps,
Dan
Im sure when I ask my local dealer about this I will get push back on doing it. But now I have an example to show them.
#33
SPONSOR
www.wheelsboutique.com
I'm looking forward to it. I've got all the photos you've posted in here already saved in a folder =)
#35
Received 3,747 Likes
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
hope this helps,
Dan
hope this helps,
Dan
I just found this thread, thanks to a link D.B. posted in the W222 section. I am seriously considering having CCB installed on a new SL. Might you post a redacted copy of the work order for the purchase/installation of the CCB package? I'm sure many here would be interested to see exactly how the dealer broke down the parts cost/installation charges.
Thanks,
Streamliner
#36
STREAMLINER -
You would be getting the CCB's thru your dealership -
Here is a link that shows what you would be getting -
https://mercteil.com/en/products/amg...lass-w222-c217
Doing this thru the dealer gives you the MB warranty -
Dan will be posting shortly to answer your questions -
Thank-You
D.B.
STREAMLINER -
Thank-You
D.B.
#37
Ok interested but have to ask you quoted $26k which is a big number. The link above shows the total at a converted rate of $14,169?? Thats a big difference what would be the difference or is it dealer discount?
If it was $26k with usual dealer MKUP that would be shop cost of $16,900.
I would think the dealer would work on that mark up with you as that is obviously not there cost.
Most shops would also discount the mark up as they make their money also on the labor if you go Indy?
What was the original option cost? I would lean on that dealer hard if done at purchasing dealer.
Looks great and I do believe CCB is the way to go especially if not in a cold climate.
#38
STREAMLINER -
Thank-You
D.B.
STREAMLINER -
Thank-You
D.B.
I am trying to get a handle on especially the labor charge. As I understand it, this is a fairly simple, bolt off/bolt on job, with the bleeding of the brake lines, reprogram, etc. Also, what became of the ever-so-slightly used original brake system? Was that retained by Dan or??? Call me crazy, but I am hoping that the labor charge is not out of this world and if I ever go to sell the car, I would probably do way better reinstalling the stock brakes and selling the CCB package to someone. Call me crazy again, but I will not be tracking the car or using the CCB anywhere even remotely close to its potential and the car will be driven very little. I just WANT the CCB for how they look and the idea of almost zero brake dust is VERY appealing. With this in mind, if my dealer or any dealer close by will not work with me on a good price, I may forgo the warranty issue and just do the install with an independent shop.
#39
STREAMLINER -
Are you talking about the 2019 SL450 you have
listed in your sidebar -
Unless I missed it I never saw that it was an SL450 -
I was just assuming that it was a SL63 - my bad -
(not that there is anything wrong with a SL450)
However I don't believe AMG CCB's are available for the
2019 SL450 -
When / if you did a build sheet were the AMG CCB's
an option that you could have checked -
I do not see that option available at this time when
doing a build on MB's website -
I also am unable to find a MB/AMG part number
for the CCB's for a 2019 SL450 -
Have you asked your dealership's parts counter
if they are available for your car -
If so do they have a part number(s) -
I am not even finding them as a European option -
I am going to look at the possibility of AMG CCB's for
other MB models cross fitting to your SL -
Don't hold your breath -
Thank-You
D.B.
STREAMLINER -
2019 SL450 -
Thank-You
D.B.
#40
STREAMLINER -
2019 SL450 -
Thank-You
D.B.
STREAMLINER -
2019 SL450 -
Thank-You
D.B.
Anyway, there is a truly fabulous thread here by a fellow who retrofitted the AMG SL63/65 CCB’s onto an SL550. Reading that and then checking part numbers, it would appear that the mounting brackets, etc. are identical across the R231 line and that the CCB will fit. If you have not seen this thread, take a look, as it is quite interesting: https://mbworld.org/forums/sl-class-...550-guide.html
#41
Again nothing wrong with the SL450 -
You may be the most sensible guy on the forum -
Well there is your cross fit application -
It sounds like he obtained the CCB's from the dealer
and had a shop do the install -
I highly doubt that an MB dealer would do the install -
So no MB warranty -
I am guessing a big part of the install is getting
the CCB's to work with your car's computer -
Great information in that thread for questions you will
want to ask of whomever before you do the install -
The OEM brakes are yours to keep -
Updates please -
Thank-You
D.B.
So no MB warranty -
Updates please -
Thank-You
D.B.
#42
"...I am guessing a big part of the install is getting the CCB's to work with your car's computer"
That is correct - see higher up in the thread. I'm fairly confident the retrofit process is similar.
#43
STREAMLINER -
Thank-You
D.B.
STREAMLINER -
Thank-You
D.B.
Here you go
Streamliner (08-02-2019)
#44
A big thanks to Dan for posting the bill -
When ordering your S Class - the $9K for the CCB's is a bargain -
And for those of you who finance your purchase the cost of the CCB's
will add what to your monthly payment - maybe $100.00 if that -
And they are a plus when selling or trading in your S Class -
Food for thought so eat up -
Thank-You
D.B.
Thank-You
D.B.
#46
Modesta - the ceramic coating cover - goes on top of the XPEL - http://www.modesta.co/index.html
Since you are local, I highly recommend Eastside Auto Salon + Mr. Sun & Tint. They do outstanding work from XPEL, Ceramic coating, tinting, and keeping your car looking new inside and out --> Joey, Ben, Rudy, and Michelle our now trusted friends and very good people at work and out of it. And I also recommend David Nussbaum from the Wheels Boutique (thewb) (david@wheelsboutique.com).
Igor Sakhnov (08-06-2019)
#49
I have not heard this from anyone with CCB. I have had dealers—both MB and Porsche—say they squeak, as they try to dissuade folks from ordering them. Since very few if any cars on their lots have CCB, there are none for them to sell immediately, which is what they live for.
Heisenberg (08-08-2019)
#50
So no MB warranty -
Updates please -
Thank-You
D.B.
So no MB warranty -
Updates please -
Thank-You
D.B.
