S63 coupe vibration when warm.....
One small thing I have noticed which I was wondering if it was a known issue.... I drove it for about 45 minutes a few days ago, only after this time ( I have only driven the odd mile here and there since buying, this was my first long journey) I noticed a vibration come from the left front side. It sounded a bit like when you apply brake pressure to drilled brake discs, however it definitely isn't anything to do with the brakes binding etc... It seemed to happen more if I shook the steering wheels from left to right and also decellerating primarily (noise was there on accelerating as well although not so prominent - could be the engine noise drowing it out though).
Any ideas? Could it be ball joint related given it does it moreso when moving steering wheel? Seems weird it only happens after long journeys, joints getting warm?
The car has done 38000 miles....
Is there a diagram of the S63's anywhere showing mechanical parts such as wishbones, bushes etc?
you will need to align it as well.
Good Luck.
