Lowering a W222 - any experience with LoMo OBD module?
UPDATE:
The OBD modlue arrived and after a bit of fussing around (the menu was a bit different - Commad wheel Vs track pad) I got it all dialed in. It was very simple and as advertised and worked perfectly at less than a1/3 cost of the LoMo1. I am at a -38 front and -35 rear.
What brand did you use? Can you provide a link to where you purchased from?
Thank you,
http://loweringmodule.com/w222-next-...wering-module/
David Gibson (01-11-2021)
Has anyone used the Next Gen LoMo M2 Lowering Module?
installation seems similar to the
LoMo OBD Suspension Module T1 but it isn't married to the car and is controlled by the steering wheel.
I got a W222 with ABC suspension and I order the lowing module from here:
