Custom Air Box - Ready For Orders
Old May 22, 2016 | 11:31 PM
speed43's Avatar
1999 C43 Amg
Ok heres the renntech air box on a w208 clk55 amg. See how low it is? So theres plenty of room for me to make my air box at least 2 inches higher. And if not than at least we know if i keep the same size as renntech it will make 10HP. But of course at a much lower price.
Old May 23, 2016 | 12:05 AM
Dziner82's Avatar
99 C43 AMG, 2001 CLK55 AMG
Originally Posted by speed43
Also, that harness will not need to go UP but down some and on back of the maf.
yea i meant theres not much room for your airbox to go UP from the stock airbox back there. harness would have to go under the engine air inlet to get any space at all.
If you get a chance and you could do one more thing?
Get that paper towel or toilet paper tube (you know once the paper runs all out) and cut it exactly 2 inches. Place it at the back of the air box by the air flow sensor. Than close the hood all the way, open and check if the hood crushed it.
yea i will try to take a look at this hopefully this week or when i next clear out a roll of TP
Old May 23, 2016 | 12:10 AM
Dziner82's Avatar
yea that renntech box looks like it keeps the same height from our 'red dot' photo and goes back to the engine inlet parallel to the gound, vs the stock airbox that tapers downward at the back as it gets near the inlet. and then yea you can try to take advantage of the inch or so of extra room for volume. but i dont think there's an inch more at the back... as mentioned i will try to check this week in more detail.
Id love to get a modified box for the clk55 as the c43 is now just a street car for me and dont really need the extra power there, but i would love to have it on the track with the CLK
Old May 24, 2016 | 02:40 PM
Denlasoul's Avatar
1998 C43
Great stuff. Can you estimate how much more volume you added? Also, like the Renntech box, the front AMG half is compatible?
Old May 24, 2016 | 10:26 PM
  #30
speed43's Avatar
1999 C43 Amg
Hard to say because I would need the renntech box to compare. But from pictures my air box is much higher.
As far as the front amg, you mean the front engine cover?
If yes than the answer is yes it fits like oem. Your air filters will also fit just like it suppose to.
Old May 25, 2016 | 04:41 AM
  #31
DRBC43AMG's Avatar
From: CH = Land of mountains, cheese, chocolate and watches
Having done the upgrade, I confirm it's a straight swap
Old May 25, 2016 | 05:16 AM
  #32
KJI3jflarryfe93's Avatar
did you have to drop the rear firewall wireloom down the firewall when you fitted the new airbox?
Old May 25, 2016 | 09:09 AM
  #33
speed43's Avatar
1999 C43 Amg
Its a small drop, look at the picture. If the black plastic cover is not removed than the modified box cannot be raised. Once the cover is unclipped the wireloom gently drops under the air box which than its out of the way. Than I can go ahead and raise the air box...Really no big deal at all.
Old May 25, 2016 | 11:04 AM
  #34
i don't have the above plastic tube cover on my wireloom.
euro cars didn't have this protection cover.
do I have to unhinge and put wireloom and plastic grey air tube further down to fit the larger airbox?
do wireloom and airbox touch each other?
your MK-II version lower airbox does it touch rear firewall wireloom or hood?
Old May 25, 2016 | 12:05 PM
  #35
DRBC43AMG's Avatar
Yes, just cut and remove the two zip ties and tuck the harness behind the MAF. Job done
Old May 25, 2016 | 03:32 PM
  #36
speed43's Avatar
1999 C43 Amg
You lost me here. I'm only making one size only and that's the tallest everyone wants/likes. The smaller one I no longer make unless someone asks for it. But my air box does not touch the wire loom, it may touch the hood padding but that's it.
Old May 25, 2016 | 03:41 PM
  #37
i thought you quit making tallest box and only making slightly shorter box?
MK II version was the slightly shorter box not touching hood insulation.
when you close the hood, do you close it carefully or slam it down?
it's no good if hood on the inside smashes onto top section of the airbox, with a massive pressure closing hood, might damage top part causing cracks in plastic or plastic clips sitting on engine breaks?
so did you find out what the best solution is to modify the internals of the airbox for best performance?
i mean, what excess plastic baffles you had to remove and what baffles were left untouched?
Old May 25, 2016 | 04:58 PM
  #38
speed43's Avatar
1999 C43 Amg
" i thought you quit making tallest box and only making slightly shorter box?
MK II version was the slightly shorter box not touching hood insulation."
- I dont know where the MK II name came from. I only did ONE small box which was like 1/2 shorter and than I mentioned in some thread I was going to make the tall one from here on. So hopefully now people will know no more short ones.
And the short one did not touch the insulation that I was able to tell. The tall one just touches a little or none as others have said in other threads.
''when you close the hood, do you close it carefully or slam it down?
it's no good if hood on the inside smashes onto top section of the airbox, with a massive pressure closing hood, might damage top part causing cracks in plastic or plastic clips sitting on engine breaks?''
- I know for a fact that nobody would have bought my air box if closing the hood smahed the air box. You can close the hood slow by pushing it down or like what I do, let it go when the pressure of the hood is down. Than it just justs close without smashing anything.
''so did you find out what the best solution is to modify the internals of the airbox for best performance?
i mean, what excess plastic baffles you had to remove and what baffles were left untouched?"
- Ive found out 3 days after I made my first air box for myself. I just gut everything that will slow air flow, specially the baffles. The main modification is going up high for better airflow..
I hope I have answered all your questions.
Old May 26, 2016 | 01:25 PM
  #39
I came up with MK II (shorter version) not to confuse with your 1st airbox which was the taller one.
i was first concerned/worried if your taller box was squashed when you close the hood?
meaning plastic clips on the bottom of airbox that snaps on engine getting squashed/breaks when closing the hood if airbox was a bit taller than your MK II design?
that's why i first thought you decided to make ONLY the shorter box?
that's good no plastic clips gets damaged or breaks
I'll get back to you when I have everything worked out.
Old May 28, 2016 | 08:16 AM
  #40
speed43's Avatar
1999 C43 Amg
I have an air box ready to ship for anyone that would like more power.
You don't need to send your air box. I will ship straight to your door. Let me know at geo3617(@)gmail.com. Thanks
Old May 28, 2016 | 03:21 PM
  #41
DRBC43AMG's Avatar
Come on guys, jump on the occasion! You won't regret it.
I'll also be doing a before and after dyno measurement using a dyno pack unit, but I first need to get my 43 serviced in order to pass the technical inspection scheduled for June 6.
The dyno will be after...
Old May 28, 2016 | 04:15 PM
  #42
speed43's Avatar
1999 C43 Amg
Thanks Daniel, your awesome.
I wanted to show how much more space my air box gives the engine to breathe. It's night and day compared to the stock air box. Also, if you want to save some money, send me your box once you have receive and installed mine.
I can offer $100.00. Renntech asks for your box and you still have to pay $1580 plus shipping. My box is an awesome deal, get your credit cards out, you won't regret it.
And if you don't see any difference in performance compared to the stock box, send it back no questions asked. But I have to charge a 20% restocking fee. But you will not send it back, you will love it. Just give the box 2-3 days for the computer to adjust and your set. But you will notice the power after a few hard runs once installed.
Old May 28, 2016 | 04:35 PM
  #43
speed43's Avatar
1999 C43 Amg
Btw, the inside still has to be gutted/cleaned up. The square baffles has to be flattened out for better air flow.
Old May 29, 2016 | 06:26 AM
  #44
DRBC43AMG's Avatar
You can also remove the metal screen. There are other screens in the MAF and with filters inside the box, you have little risk of UFO's being sucked inside the engine...
Old May 29, 2016 | 08:28 PM
  #45
PJmak's Avatar
So how much for a modified box if I send you my stock one?
Old May 29, 2016 | 08:56 PM
  #46
speed43's Avatar
1999 C43 Amg
Send me an EMAIL, no PM please. I will give you a nice deal. Let me know if your in the USA. Thanks
Old May 30, 2016 | 09:40 AM
  #47
speed43's Avatar
1999 C43 Amg
Guys to save some time on emails please know that if you want to send your air box TOP PART ONLY, I can reduce the price of my air box between $100-120.00 depending on condition. Once I receive and inspect the box I will refund you the money.
Also know that if you really want to purchase one, I will need your payment with PayPal. Once I've received the payment I will ship the air box IF one is available. If none are available I will start on one right away and when done I will ship and send you a tracking number.
My goal is to always have 1-2 available. But I'm also starting to mod other Mercedes air boxes so it will be hard to have these always in stock. I've sold the one I mentioned here a few days ago but right now I have one almost ready to ship. It's the one I posted a picture above. First person to send the payment gets it. Thanks.
Old Jun 4, 2016 | 01:04 AM
  #48
COOPERDB's Avatar
NB8 PARACHUTE
Yes
Thank-You
D.B.
Old Jun 7, 2016 | 06:48 PM
  #49
BlownS4's Avatar
2015 E63 - Current, 2012 E550 - Current, 2019 Audi Q7 3.0T - current
Hey George please check your email. I responded to your PM my email would have come from wurteaga@connectunow.com I'm very interested in what you want to do for the E550 BiTurbos
Old Jun 7, 2016 | 07:49 PM
  #50
speed43's Avatar
1999 C43 Amg
I'm sorry I haven't been able to answer emails regarding making these air boxes for different cars. I have had requests for models I've never even heard of. But right now I had to move out of the garage I been working from so its going to be a while before I get back to modding these. For the air box of the c43 I can make within a week. But the others it will take one time. Sorry but that's where I'm at right now.
