C63 AMG (W204) 2008 - 2015
Let's see all the c63's on H&R springs (or anything)
Old 02-24-2016, 12:19 AM
  #151
Mrmendoza's Avatar
2019 C43 AMG
Originally Posted by Fung63
on H&R springs
Old 02-24-2016, 02:29 AM
  #152
Shadykit's Avatar
C63
These H&R drops looks soo nice. Are the H&R softer then OEM springs? I have a set sitting in my garage, contemplating to install or not?
Old 02-24-2016, 11:21 AM
  #153
AMG3.2's Avatar
C63 AMG, P30
Just a tad softer than P30 springs but harder than non P30. Not very noticeable at all though.
Install 'em!
Old 02-24-2016, 09:09 PM
  #154
Shadykit's Avatar
C63
If thats the case, im going to install. Thanks for the info.
Old 02-25-2016, 07:21 PM
  #155
Duals1ns's Avatar
MY2010 6.3///AMG Markus Jaudes
Originally Posted by Roswell
Interesting paint scheme on the CF lip & rear skirts. Any plans on sideskirts to match?!
Still waiting for shipment to arrive...(out of stock)...
Silver CF wrap
Old 07-25-2016, 04:11 PM
  #156
DiMaio63's Avatar
2012 c63 AMG Sedan + P31, Magnetite Black Metallic / 2011 c300 sport sedan
Hello everyone, trying to get some advice here. I think I'm finally gonna give in and get H&R lowering springs & spacers for my 2012 c63 sedan. All of my questions seemed to be answered on this thread except regarding installation..
4 years ago a friend and I with a few beers installed h&r lowering springs on my 2011 c300 sport sedan, the process wasn't too difficult, just time consuming.
Has anyone installed springs on their c63 themselves? Seeing that the process takes 4-5 hours, I could save $500 by doing the job myself, instead of taking it to a shop and paying $100/hour. I just don't know how much I trust myself ripping apart an AMG haha.
Old 07-25-2016, 04:25 PM
  #157
AMG3.2's Avatar
C63 AMG, P30
Totally doable just a pain in the butt.
Fronts are your typical McPherson strut and rears are your typical multilink.
Spring compressors + Hand tools + Impact wrench for the front
For the rear: Just get a triple square socket to remove the control arm bolt. I forget the size but get the stubbiest ratchet you can find as space gets tight when removing the bolt to drop the control arm in the rear.
Drop if from the center of the car as opposed to the bolt closer to the brakes.
Also, make sure to buy the right sized shims for the drop you want. You can see pics of 5MM in my build thread as well as everything in between on this forum.
DiMaio63 (07-25-2016)
Old 07-25-2016, 04:39 PM
  #158
DiMaio63's Avatar
Thanks for the quick reply, I just wanted to know what I was getting myself into with the AMG. Haha I know the process is a pain, but the more money I save on installation the more I can blow in the long run lol. When doing installation on my c300 the process took like 8 hours (but it was just a friend and I at the age of 16 haha) do you think the normal installation time is closer to 4 hours?
Old 07-26-2016, 01:33 PM
  #159
604 C63's Avatar
2012 E550 Cabrio
This. And just cut to the chase and drop your exhaust right away. Its gotta get outta the way. I did this job once. Once. With a floor jack, in a single garage, in August. And Im glad I did it cos I learned a lot about my car. Now on this new one I paid a shop. $400. Totally worth it. Just did it on Friday. Here it is now.
Old 07-26-2016, 01:37 PM
  #160
AMG3.2's Avatar
C63 AMG, P30
I didn't drop my exhaust, but unhooked it from the hangars and flexed it out of the way...
In hindsight, maybe I should have dropped. Luckily, I had exhaust work done a week later and had the shop completely adjust my tips since I think they had moved around a bit. Definitely keep that in mind.
Old 07-26-2016, 01:41 PM
  #161
604 C63's Avatar
2012 E550 Cabrio
The flex technique wasn't......quite......getting.....it.....to where it needed to be. I swear, I could do this job in half the time this time, but still wouldn't unless I had a lift.
Old 07-26-2016, 01:46 PM
  #162
DiMaio63's Avatar
Car looks great! Are you running the 17mm pads in the rear or did the springs just not settle in all the way yet?
Old 07-26-2016, 01:59 PM
  #163
604 C63's Avatar
2012 E550 Cabrio
Both. 17mm pads, and those are brand new springs installed that day. Front may settle some with the weight of the motor right there, wouldn't expect rear to move much.
Old 07-27-2016, 12:35 AM
  #164
Silversun262's Avatar
86 Targa, 91 560SEL, 06 E55 Estate, 13 C2S, 21 MACAN GTS, 05 R6 Track, 15 R3 RACE BIKE
Always imagined these vossen on my S550, never thought about them on a C63. HOT! and Original!
Originally Posted by durranic
here goes mine
Old 07-28-2016, 01:16 AM
  #165
oggie's Avatar
2011 E550 4Matic & 2010 Audi Q5 & 2015 C63 507
Old 07-28-2016, 09:05 PM
  #166
ev4530's Avatar
2012 C63 P31 Coupe
Old 07-29-2016, 11:13 PM
  #167
jay rick's Avatar
C63 2009
Can any one with 18 stock wheels tire size measure how high the car sit from ground to the fender arc edge?
Thank you.
Old 09-01-2016, 08:09 PM
  #168
DiMaio63's Avatar
H&R Springs & ECS Tuning Spacer all around.
Loving the new stance!!
Old 09-01-2016, 08:24 PM
  #169
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
^^ so sick!!
Old 09-01-2016, 08:31 PM
  #170
DiMaio63's Avatar
thank you! couldn't be happier, I'll post more photos once they settle in!
Old 09-01-2016, 08:38 PM
  #171
jay rick's Avatar
C63 2009
May i ask what lengths bolts are you using on those 10mm spacers?
Old 09-01-2016, 08:57 PM
  #172
DiMaio63's Avatar
You will need 37mm bolts! The ECS Tuning spacer kits I bought came with 40mm lugs. Had to get them shaved down 3mm to clear the parking brake in the rear, 40mm was fine up front with my 12.5mm spacers.
Old 09-21-2016, 03:09 PM
  #173
itzjonjon69's Avatar
12 C63 Coupe
so are the 17mm spring pads a requirement on the coupes or is it just the sedan?
Old 09-21-2016, 03:31 PM
  #174
DiMaio63's Avatar
honestly they aren't required at all. But it helps keep the same rake as the stock suspension. If you were to leave the 13mm pads the back end would sag (and sit lower) when the springs settle in.
Old 09-21-2016, 03:33 PM
  #175
12 C63 Coupe
Even for the coupes? I've seen two threads so far stating that the coupes don't suffer the sag as much as the sedans, so that confused me
Quick Reply: Let's see all the c63's on H&R springs (or anything)
