My car started dialing last week
Old Aug 30, 2016 | 04:49 PM
cdnclk3202004's Avatar
clk 320
I own a 2004 CLK320.
Last week I was driving and a message came on my car saying trying to connect. The car made a noise, I turned if off and the problem went away.
Anyone else ever experience this?
I believe my car came with some phone option.
I have owned if for 3 years and love it to death.
Old Aug 30, 2016 | 09:04 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
jk...do you have bluetooth?
Old Aug 30, 2016 | 09:49 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I suspect you activated TeleAid.
Old Sep 1, 2016 | 10:22 PM
clk 320
Correct, I get an error about tele-aid.
But I have never activated it, dont know how.
What is it.
Old Sep 1, 2016 | 10:39 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
TeleAid is like GM's OnStar - it is a "telematics" system that allows the car to communicate with a central call system via a cell phone connection. There is a red SOS button on the overhead control panel that calls for emergencies, and "i" and "wrench" buttons inside the center console used for concierge and roadside assist calls, respectively. Your car has the older analog cellular system which is obsolete, so it can't complete the call anyhow. If you press one of these buttons, it will attempt the call and you'll have to wait until the system times out.
Old Sep 3, 2016 | 02:12 PM
clk 320
Thank you kindly for your detailed explanantion.
is there a way to get rid of the error message I get when I turn off my car.
Tele-aid not connected.
Old Sep 3, 2016 | 02:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Sometimes pressing one of the call buttons and letting it go through an entire cycle of trying (which can take 10 minutes or so) will clear it. There may be an actual fault in the system, like a bad antenna connection, that can cause an error needing SDS to clear. Actually, the best thing would be to deactivate TeleAid, which does require SDS. Te dealar can do it - they'd probably charge an hour's labor.
