IAT logs and what not
Old Aug 28, 2016 | 04:15 AM
Atk_gaming's Avatar
2005 e55 amg, 2005 audi s4, 2000 audi a4 1.8T (big turbo)
Hey guys so just curious what is consider optimal intake air temperature in our cars with 77mm pulley?
I did some logs and im seen 65 Celsius at idle fully warm, about 32 Celsius at 65mph and stays like that and at full thottle for 5sec it climbs to 58 celsius the starts to go down as i cruse, about 78 degrees outside temperature coolant about 90 celsius so yea with a wistec exchanger and dual intakes.
So what do you guys think to hot or just about right or pushing the limit?
Old Aug 29, 2016 | 12:51 AM
Rocman8's Avatar
E55
Sounds about right
Old Aug 29, 2016 | 01:32 PM
Atk_gaming's Avatar
Originally Posted by Rocman8
Sounds about right
Cool all tho i feel the car pulls timing a bit at times i can even hear the exhaust not change to a more lazy firing.
Old Aug 31, 2016 | 04:57 PM
V-AMG's Avatar
2016 E63s Wagon - CCB & CF package
Your idle temp seems high to me. 65*C is 149*F at idle. At 78*F outside, i would be around 98*F (36-37*C) idling and maybe 92*F (33*C) while cruising. You report about of 32*C (90*F) while cruising so that's spot on.
Given, i don't have a 77mm pulley but the pulley is disengaged at idle and cruising anyway...
Old Aug 31, 2016 | 04:59 PM
Atk_gaming's Avatar
I see but 77mm is actually clutchless so i think thats why im high at idle.
Old Aug 31, 2016 | 05:15 PM
V-AMG's Avatar
Gotcha, scratch all that then.
Old Aug 31, 2016 | 05:24 PM
Atk_gaming's Avatar
I got a bigg *** heatexchanger coming soon by friday i think that will help uts bigger than my wistec and bigger than eurocharged so will see what the logs say then
Old Sep 6, 2016 | 03:24 PM
Atk_gaming's Avatar
Different intake test shocking results
So i was running full intake you know the one everyone uses on the e55 amg with the dual filters and i notice my IAT are really high well for my taste atleast.
Now what i notice
Full dual cold air intakes
60-62°C at idle engine at full temperature.
32-37°C crusing
52-61°C full throttle 3rd gear pull till red line.
Now i know this sounds crazy but i ran dual filters short ram under the hood and this is what i got
50-55°C idle
27-30° crusing same speed as other test.
42-50°C full throttle 3rd gear till red line
So as you can see i got better results with short ram how idk but even the recovery after a pull was better and faster. Both about 76° outside temperature. With short ram outside temp 76 degrees.
Average crusing speed during both test.
Old Sep 6, 2016 | 03:48 PM
V-AMG's Avatar
Now what i notice
32-37°C crusing
50-55°C idle
Do you have pics of the 2 setups? Im baffled by the results so im very curious what the 2 look like.
Thanks!
Old Sep 6, 2016 | 06:23 PM
C32owner's Avatar
2018 E63s AMG (Current) 2011 CL63 AMG (Sold) 2005 CLS55 AMG (Sold) 2004 C32 AMG (Sold)
Interesting, do you have pictures of both your intake setups... Or even what you have now getting the better results, short ram.
Old Sep 6, 2016 | 06:50 PM
Atk_gaming's Avatar
Yea ill take pictures im also just shock but i left the ram bc numbers dont lie , i think it has something to do with the long tubes been heated up by the headers and then all the friction it does from traveling.
Old Sep 6, 2016 | 07:36 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
That is strange. Can't argue with those results.
Old Sep 6, 2016 | 10:37 PM
BlackHammer's Avatar
2006 E55
Thanks!
What did you do to get the +185 F to appear in the lower center of the speedo?
I am assuming that it coolant temp?
Thank you,
TK
Old Sep 6, 2016 | 10:39 PM
Atk_gaming's Avatar
Thank you,
TK
Oh that no thats my ambient temperature lol sensor is busted have not replaced it .
Old Sep 6, 2016 | 11:09 PM
2006 E55
DANG I thought "that is pretty cool" and was wondering why I had never seen it before.
Old Sep 13, 2016 | 02:43 PM
Atk_gaming's Avatar
Tested again this is what i got
Thanks!
Again tested with short ram this are the results all done with engine at full operation temperatures
Idle 0 mph i got 42-47C°
Crusing 70 mph 24-27C°
Full throttle 35-50C°
Outside temperature was 60 degrees/ 15.5C°
Im loving this thats only 15 degrees hotter inside the intake vs outside . . So how the hell is a ram more efficient ?? Lol literally i got ebay filters.
Ama test with the cold air intake again see what i get.
@78 mph seems to stay the same .
@68 mph seems to go up by 1C° so from 65mph to 80mph there is only 1C° difference
Old Sep 13, 2016 | 03:16 PM
V-AMG's Avatar
So just two cone filters instead of the snorkels? I know im repeating myself, but a photo would be awesome
Old Sep 13, 2016 | 03:18 PM
Atk_gaming's Avatar
Yea a T then 3" 90 degree short pipes with filters and their heat shield i know it sounds crazy , also let me get out for lunch at 3pm and ill snap a pic im at work atm.
Old Sep 13, 2016 | 06:01 PM
Atk_gaming's Avatar
Bam cheapest intake yet effective idk how
Here u go bro see very simple setup
Old Sep 13, 2016 | 06:40 PM
C32owner's Avatar
I got a load of logs as well mate with my 77mm upper (clutched version though) with stock intake and stock intercooler. Would be more conclusive if you can get wide open throttle speed runs and we compare. Basically what I did was start a pull in 3rd gear and only that gear floor it from about 60kmph up to 220kmph and I noted the start temp, and end temp and then recovery times basically, obviously noting the outside air temp to for each run. So instead of saying full throttle for 5 secs your end temp variance is quite a bit.. Give it a good run longer than 5 secs and let's see what temp you end up at.. If you game
