Burmeister Speaker Rattle/Buzzing - Video Recorded
My guess is that the black plastic grille has enough give to keep the A20 from buzzing where the metal grilles do not.
FYI, I have the Burmester system, just to clarify.
Anyways, after they heard that, they wrote a report to Mercedes in Germany stating the issue, and they came back to them a few days later saying that there is now an 'official' fix for this known issue.
So I brought my car back a third time, and they were finally able to fix it.
After testing the system for about an hour now, I can say the problem is pretty much gone and the Burmester system is sounding really badass. While at the dealership I tried my tone generator at the frequencies that used to buzz and I was really surprised there was absolutely no buzz even at really loud volumes. Also tried phone calls and some songs that used to produce that buzz and it is completely gone!
Couldn't be happier with the results so if anyone is interested in the exact wording of what was performed on the car I can post it on here sometime. Just wanted to report this update for other users out there who have the same issue.
Thx man and glad it's fixed for you!!!
"only" going with the Bose this time as I'm really disappointed by this experience.
Here are some side by sides between the "Burmester" 4" mid and tweet vs the Harman/Kardon 4" mid and tweet from a W221 S Class.
W221 Harman/Kardon (left), W205 Burmester (right)
I miss the exhaust note and the style of the C63S interior looked nice but ultimately BMW just feels so much better put together. I'd consider a E63S for the next car but then I've read the new E class isn't exactly well put together either which is a shame. Mercedes need to do better.
HK and Burmester seem to use the same sort of software that augments the outgoing sound to enhance acoustics/treble. Some earbud technology came out with this...I think i threw them away after all, and they were like 140 bucks...
Not to mention, Theres no way around the fact that these speakers are attached to a small amplifier......
Also the door speakers are all on passive crossovers, with a cheap capacitor glued to the back of the cheap off-the-shelf silk dome tweeters. That and the lack of any proper midbass woofers, leaving the boomy "Frontbass" speakers to play way up into the mid range. That's why, while the system is passable at lower volume levels, when you roll it up the mix disintegrates. The mids get shrill and overpowering, and the bass goes loose and sloppy.
I get that metal grilles are snazzy, but is anyone shocked they buzz? I'm wondering if the problem is more prevalent with the metal door trim vs the ash or lindenwood. Mine didn't buzz either with the OEM or Focals.
Do you have to remove the door panels to get the speakers out or can you access then through those snazzy metal grills? I have the coupe....
