Exact 3m Part number equal to MB Part for Spoiler
Can anyone confirm the 3m double sided tape mercedes uses to mount a spoiler to the w204 on the trunk?
I have recently purchased an oem mercedes amg?/c350 spoiler color matched and would like to know the best 3m double sided tape to use. I would like the exact part number from 3m if possible, or a mercedes part # if there is one.
Thanks in advance.
Thanks in advance.
Just need opinions or experience with exact 3m tape to use. any one else have any input? thanks already for the help.
I used to be in the membrane switch industry and we used that in outdoor and extreme environment applications. Works extremely well provided the mating surfaces are cleaned well.
I used 3m 5952 .5inch wide 15ft long, was more than enough to make sure the spoiler isnt going anywhere.
I prepped with rubber 3m wheel 07498 to get all old adhesive off ( you can skip this if new spoiler)
I then washed tunk lid and spoiler with soap and water. let dry or dry with microfiber.
Then i used ispropal alcohol 91% to wipe down spoiler and rear deck lid.
I then heated up deck lid and spoiler until hot to touch with heat gun.
Layed tape down on spoiler first and heated that up hot to touch with heat gun.
Then lined up with 2 people on trunk to get an idea for edge gap.
Took off backing and heated both pieces up to hot to touch again then layed spoiler starting at one edge.
Heated spoiler for 15 minutesand lid after and let sit over night. It was 68 during the day and sunny, then dropped to 30 at night. cold for next few days. The documentation says if you can get it to 70 for an hour it drys to 50% or more strength. 150 or more for an hour is full cure. So thats why i hit it with heat gun for a while. It was probably 80% strength when I had left it after initial install due to heat gun.
Thanks in advance.
The tape is Genuine 3M 1/2" (12mm) x 15 Ft VHB Double Sided Foam Adhesive Tape 5952 Grey Automotive Mounting Very High Bond Strong Industrial Grade (1/2" (w) x 15 ft)
You will only need 1 roll. This is more than adequate. I did 2 strips of the .5inch on the top face and 1 strip on the rear face.
If you are buying a used spoiler, make sure to grab one of these 3m strip off wheels. They work for other stuff too.
3M Stripe Off Wheel 07498, 3/8" Mandrel, 4" Diameter x 5/8" Width,
You will also need a microfiber cloth that doesnt leave dust residue, goo gone and also iso alcohol to prep surface rright before applying tape.
Attach tape to spoiler then spoiler to deck. It is easier with 2 people, although i did mine by myself.
