2013 E63 AMG Timing Chain
Old Apr 17, 2017 | 04:54 PM
my bandit's Avatar
2012 Holden Ute
I'm looking at an E63 AMG that has a misfire. It just underwent a Renntech tune and while on the dyno, it supposedly had the timing chain skip a tooth. From what I know, the valves are undamaged but that's unknown until the engine gets completely checked. However, is this a common problem? I'm expecting the replacement would be around $3k from the dealer to replace the chain and gears.
Old Apr 17, 2017 | 05:22 PM
chiromikey's Avatar
'03 E55, Range Rover Sport Supercharged, Ducati 748R
Not that it couldn't happen but I've never heard of this on any of the AMG platforms...
Old Apr 17, 2017 | 05:37 PM
my bandit's Avatar
2012 Holden Ute
I haven't been able to find anything about this happening either. Granted I'm well versed on the GM LS platform where it can happen but I know these timing chains are much more robust than the LS engines.
Old Apr 17, 2017 | 05:54 PM
chiromikey's Avatar
Are they sure it's a timing chain? The common misfire associated with tunes is due to spark blowout. Have you confirmed the misfire is for an entire bank of cylinders rather than 1 or two?
Old Apr 17, 2017 | 06:13 PM
gaspam's Avatar
2014 E63s amg 4matic, 2009 C63, 2006 E55 AMG , 2001.5 AUDI S4 stg 3+ w/meth
^ +1, unless they have direct evidence that it was timing chain skip, I would think it is plugs as its pretty common on tuned M157 cars
also a motor with a jumped timing chain will have slow/hard starting because the firing sequence is retarded due to chain that has jumped a tooth, two or more teeth probably wont start at all.... so if your car is starting fine then i doubt timing chain has jumped
Old Apr 18, 2017 | 10:49 AM
2012 CCB E63's Avatar
2012 E63
Whomever you are speaking to is telling you
No way it 'skipped a tooth' these are dual over head cams with multiple chains
It's possible the adjusters are worn out and there is a bunch of slack/noise but no way it 'skipped a tooth' and didn't do damage to the valves.
There are plenty of E63s out there, skip/run far away from this one.
Old Apr 18, 2017 | 11:20 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
What everyone else said.
If you are worried about the misfire start off be removing the plugs and inspecting their condition.
