Bizarre solution to "Rotten Egg Smell" in cabin
"Crap, what is it?" I asked myself..."bad fuel"?...but that would mean an exhaust leak in the engine bay...somewhere near the cabin air filter....
"Bad catalytic converter?"...again...an exhaust leak...exhaust itself DOES NOT smell.
What about hydrogen sulphide? OMG my battery is exploding!!....nope...that's out back in the boot...and it's fine
So what's close to the cabin air filter?.....well.....there's the cap for the windscreen washer fluid....but that just water and soap and it can't be....
OH MY F-ING GOD!!!! I popped the cap off the windscreen fluid reservoir and took a whiff!!
It smelled like a thousand rotting eggs...
I don't know why, because I go through the stuff pretty regularly, but the no-name washer fluid I've been using and the water itself had gone septic.
I drained the fluid completely by using a long tube and the sprayer-trigger from a spray bottle...then I filled it with boiling water and a cup of bleach. I let that sit for a while, then used my hose to flush it for 30 minutes.
I filled it with clean water and a teaspoon of bleach.
Unreal...of all the things that I would not have expected.
i'd follow up with pouring hydrogen peroxide wherever you feel could have odor, then follow up with some Klima Cleaner to clean out your interior vents.
Trust me, it was the washer fluid reservoir, I gagged when I smelled it.
I think they they might be heated, which could have caused the cleaner fluid to react?
I wonder if the reservoir had a reaction with the windshield fluid?
