22 inch Rims on 2008 S550
I just my car back from Mercedes and got some 22 inch Rims put on the car. 245 / 30 / 22 on the front and 295 / 25 / 22 on the back.
The back left tire rubs when on the freeway even with only me in the car, eventhough they promised it wouldn't.
They look so nice, but I don't want it to rub, that's just stupid. Anyone know what the back tire sizes should be to prevent this? It used to have 265 19s. I'm not sure why they upped it to 295. It looks like the front tires would fit in the back.
Anyone have any info?
Thanks!
Thanks!
Former Vendor
Any AMG Thats Around..
Thanks!
Thanks!
the fenders might have to be rolled ever so slightly... are there cuts on the sidewall of the rear tires? are there marks on the inner fender or the edges of the rear bumper.....
or go one size down in width to a 285/25/22... and that should take care of the problem....
You don't have to roll the fenders, you can keep that tire size.
If you look on the back wheel well, look at the area where the rear fender meets the top corner edge of the bumper there is a small triangle shape that sticks out . 99% of the time that is the spot that is hitting the rear tires. Shave or cut that section and it will eliminate your problem.
1 Post
Mercedes benz s550 & mercedes benz s430
Thanks!
Thanks!
Cut the triangle and keep the 295's on the back.... only way to do it and look REAL good while doing it! Its what I have on mine and I wouldnt change a thing....
Thanks!
Thanks!
unless you plan on driving in a dead straight line at <155mph - the car drives MUCH better on the 235 width tyres they originally designed the car with
big wide tyres destroy its ability to go around corners and be agile in anyway - so if you generally drive on roads with corners and the odd road imperfection I not got too big or too wide - note there is far too much rear grip on 235's as it is, so you don't need anymore for traction
if I was a hairdresser and didn't know how to drive, I'd probably have 255s on 20" rims and start saving a few thousands for another set of wheels as they crack each week
