Serious steering wheel vibration when car is stationary
Old 06-06-2010, 08:58 AM
Kain's Avatar
My father has a 2009 S350. When the car is stationary and you turn the steering wheel fairly quickly in either direction, it vibrates violently with a loud "chuddering" sound. However, when the car is moving (even at low speeds), if you turn the steering wheel, there is no vibration or sound.
What could it be?
Old 06-06-2010, 08:19 PM
nyca's Avatar
power steering fluid low?
Old 06-20-2010, 11:52 AM
Kain's Avatar
The dealer said it's normal.
He said that the friction from the tires when turning the steering wheel when the car is stationary causes the vibration.
Old 06-20-2010, 08:21 PM
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
the dealer may be rite.
Old 04-30-2024, 09:03 PM
Rowaid Abdullah's Avatar
s550 MB
I have same issue
I have the same issue i was looking to change the oil pressure switch to fix it , did you have any luck fixing it
Old 05-01-2024, 05:11 AM
BOTUS's Avatar
S500
you are not meant to (and have never been meant to) operate the steering on a stationary car - it needs about 8 horsepower and is just damaging stuff for pointless fun
if you have ABC suspension I'd get it checked out - if std airtragic suspension, check the belt and the PAS fluid level - and maybe spend the money on driving lessons
Old 05-01-2024, 05:23 AM
BOTUS's Avatar
S500
just read the bit where it does it rolling at low speed - re that 8 horsepower - that's more than enough to make a worn belt slip - you could abuse the system with the bonnet open and get a mate to see if the belt goes mad....
the system is way underpowered to handle high speed wheel movement - especially at 550rpm tickover
Quick Reply: Serious steering wheel vibration when car is stationary
