Anyone notice low grinding noise when driving or turning slowly?y
Noticed it on really slow turns but not always consistent. Kind of like a low grinding noise emanating from center area of car to the back. Doesn't feel it's coming from the front. Anyone experience anything similar? Other than that, no issues when driving and steering, just at very low speeds like 10mph or less.
Cant say I have either heard it, or heard of it, in the C63.
I am however thinking of diff, especially if you have the LSD. If the LSD was the fluid changed at ~3000km??
A grinding sound from the rear on low speed turns, similar to what you are describing, was common place in the BMW E46 M3, all of which had LSD as standard. It was fixed by replacing the standard diff fluid with one that had a friction modifier additive and then doing a few full lock figure of 8 turns to spread the new fluid through the sytem. This fixed mine straight away and I never had any further problems with it.
Mercedes C63 amg, Bmw X5,
I think the problem lies with differential because I was never told that anything was wrong with my steering wheel or anything.
Thanks guys. I only have 8k miles on my car, and probably only 4k with the Quaife LSD, but I will have it double checked to see if that's the issue.
I think it may just be the normal process of the parts of the chassis moving because this isnt a consistent noise and not something I noticed (although I almost always have the music on) when I first got the LSD installed. I only noticed it because I was in a parking lot with friends, the stereo down low, and was making a slow sharp turn.
I've seen people complain about the noise with before they break-in. Other times, the dealers were being idiots and putting in the wrong fluid into the diff. Take it in and you should be covered under warranty.
Check your sway bar bushings/links - mine are already worn and making a ridiculously loud clunking noise. This initally started as a low grinding kind of sound but is a full clunk now. I'll be replacing them this week...mind you, I'm only at 15K miles right now...seems way too early for this kind of wear and tear.
Sorry to resurrect an old thread but anyone manage to fix this ?
I have low grinding noise from rear half of the car when going very very slowly almost to a complete stop
Weirdly it only happens after the car is warmed up doesn't happen right off the bat when it's cold
Lsd oil was changed just 2000 Miles before
Currently about 35k Miles 2010 p30 car with lsd
