Puddle lights
Puddle lights
Puddle lights (the little lights under the outside mirrors. Anyone know how to activate them? My door lights come on but the puddle lights do not.
Help!!
Help!!
Setting in comand last menu?
On top of my head 'car'-menu(or whatever its called in English),
browse down,then should have something like 'comfort-lighting' setting?
When my interior lights are in the 'off' position, the entry lights don't come on. In the 'auto' position, the entry lights come on as they're supposed to. Same, on the R and CLK.
Guys, thanks for trying to help.
I don't think it is the bulb because neither side works. I've went into the command system and made sure the outside lighting was selected, at least I think I did it right. The lights at the bottoms of the doors come on when you open a door, the floor lights also come on. The only thing that doesn't come on is the two puddle lights at the bottom of the out side mirrors.
If any one has an idea to make those light come on I would surely like to hear it.
Tony
Tony
I have the same problem and already make sure I turn on the lights on my command. I try it at night also and not lights up.
any idea? may be there is a fuse somewhere?
thanks,
thanks,
Received 4,415 Likes
'71 Pinto
Check locator lighting setting...
bensitto (03-21-2019)
SPONSOR/MBworld Guru
Should just be a 194 LED wedge bulb
Konigstiger, Just try it last night and it works! I am going to swap the side mirror to 2011-2013 and put a pair of 194 LED light bulb before install on the car!
Thanks a lot for help.
